Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: joesatch on September 07, 2023, 02:06:40 pm
Can these stages be replicated with LND's? wrong answers only. I want to avoid using a tube for this output stage as it is only for boosting the level, not part of the preamp
OK, I think I can provide a wrong answer; only if shaken, not stirred.
http://www.geofex.com/Article_Folders/mosfet_folly/mosfetfolly.htm
ok i replaced the triodes with LND's the result is quite good although less bass (i guess just cleaner) than the triode and output is considerably higher. i will need to play with the voltage divider to get the output manageable. I will go with this. there is some mention of using diodes to protect the transistor and possibly a 200R resistor somewhere but i'm unsure where.
