Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Duncan on October 24, 2023, 09:49:07 am
Title: Stumped by Marshall DSL40CR standby switch issue
Post by: Duncan on October 24, 2023, 09:49:07 am
Hey guys,
I’ve been working on a Marshall DSL40CR that came in with some output issues (which I determined was a burned up dropping resistor which has been replaced).
For those of you not familiar with this amp, the standby switch is a three position switch that goes low-standby-high.
For some reason, the middle position does not put the amp into silent standby anymore. I’ve tried disconnecting the switch and cleaning the contacts (also with contact cleaner inside and actuated) and the issue persisted
I’ve confirmed with Marshall that the switch is wired properly, and I’ve worked through the schematic and found nothing amiss.
Does anyone have any ideas as to why this is happening? I’ve attached a schematic that Marshall sent to me for this amp (well, for the 100 W, but it also applies to this model).
Thank you in advance.
Title: Re: Stumped by Marshall DSL40CR standby switch issue
Post by: sluckey on October 24, 2023, 10:34:03 am
Does the voltage on the plates (pin 3) of the EL34s go to zero when the switch is in standby position?
Post by: Duncan on October 24, 2023, 10:54:49 am
No it doesn’t. Voltage in the “high” mode is 440v, “low” mode is 161, and in “standby” it’s sitting around 315.
Post by: sluckey on October 24, 2023, 11:11:29 am
How many lugs are on this switch? If it's a SPDT with center OFF (three lugs) as shown on the schematic then the switch is faulty or wired incorrectly. Show us a pic of the actual switch.
Post by: Duncan on October 24, 2023, 11:31:25 am
Here is the Marshall switch:
https://i.imgur.com/Mu5Hftk.jpg
https://i.imgur.com/1eEis5w.jpg
And here is the replacement I have (which will require me to combine the lower two banks onto one side of the switch, as it is a DPDT):
https://i.imgur.com/10MntRn.jpg
This is the model of switch:
https://www.digikey.ca/en/products/detail/bulgin/C1570AABB/4319306
Post by: JPK on October 24, 2023, 11:56:33 am
Slucky please don't mind my amateur attempt here. I like troubleshooting but no where near you level. So...if you disconnected the switch and there was still voltage then it's not likely the switch right? Something down stream is shorting out some HV+ to the circuit. A failed trace or a component? Assuming nobody made a change to the wiring.
Post by: Duncan on October 24, 2023, 12:15:19 pm
To be fair, I've not attempted firing up the amp without the standby switch connected. I've heard from a (relatively) local Marshall warranty shop that the switches in these amps are prone to failure.
Post by: sluckey on October 24, 2023, 12:47:21 pm
I'm sure you took a pic of that switch before you disconnected any wires.
Post by: Duncan on October 24, 2023, 12:50:45 pm
I did, yes. Connections are consistent.
I’ve also confirmed the connections with Marshall (attached)
Post by: JPK on October 25, 2023, 10:33:05 am
Ah ok, I misread that. You took the switch out to clean it, not to see if voltage is still there with it disconnected. Hopefully your new switch is the ticket.
Post by: idontknowyou on February 16, 2024, 12:32:39 pm
Any update on this?
Im encountering the exact same problem on a DSL40CR. Slightly lower HT on the plates and screens whem the switch is in "standby." Got a replacement switch and the problem persisted. The schematic has me stumped, I can't even see a possible path for voltage to be present there when the switch is off!
Post by: WimWalther on February 17, 2024, 02:40:15 am
Any update on this?
The schematic is somewhat unintuitive, and it seems that the standby switch isn't drawn properly.
From what I can tell, it's a 3-position switch (SP3T) with two "on" positions and one "off". It's this 3rd (off) position that isn't shown.
In any case, the "on" positions select either the upper (higher volts) or lower (lower volts) B+ power supply. In the unmarked (center?) position, neither supply is selected and the amp is in standby.
There should be no B+ other than residual in standby. If there is still steady B+ in standby, high or low volts, the switch is bad.
Post by: idontknowyou on February 17, 2024, 12:52:39 pm
Yeah, I tried a replacement switch and the problem persists. Both the original switch and the replacement are DPDT on-off-on switches with 6 terminals. Both tested fine with a multimeter out of circuit.
I agree there should be no voltage present when the switch is in the middle off position. It seems like one half of the switch is switching between two different power supplies for the HT. If we have to assume the switch is working properly, is there any other path for voltage to be present at the power tubes?
Post by: WimWalther on February 18, 2024, 09:29:04 am
Ok, so they're double-poled switches. Are both sets of poles in use? All 6 terminals?
FWIW, I can't presently see any other current path.
Of course, the schematic could be in error, or I could be misreading it - either are possible.
And you're sure that it's not just residual? That is, the amp remains playable in "standby"?
Post by: mresistor on February 18, 2024, 01:00:26 pm
Wim in Reply # 4 he has provided pictures of the switches which should answer your question above.
Post by: idontknowyou on February 18, 2024, 02:03:24 pm
Yeah, the amp is remaining playable and passing signal even when in standby. Sitting in the 300 volt range, same problem the OP had.
The second set of poles seems to be switching a ground connection for relay 2 and IC4? It also has paths to LT1, low1, and low2, which i dont see in that page of the schematic and I assume are going to the preamp.
I also don't see any other possible path for HT voltage and am utterly stumped.
Post by: WimWalther on February 21, 2024, 01:35:51 pm
Next step is to determine which B+ supply is sourcing the mystery current. Check for voltage drops across the resistors in each supply.
If a supply is sourcing current, you should be able to tell by the drop(s).
