Other Stuff => Electronic Projects => Topic started by: mgalicki on February 22, 2024, 09:16:59 am
Title: Crate V-33 power supply issue
Post by: mgalicki on February 22, 2024, 09:16:59 am
I have a craete V33 the power supply when out from a power surge at my house. I am unable to locate one to purchase. Is it possible to use 2 alternate power supplies in it's place ? pic attached. Thank you
Title: Re: Create V-33 power supply issue
Post by: shooter on February 22, 2024, 10:01:07 am
read a statement once in an 'ol Book; "ALL things are possible...."  :icon_biggrin:
any old "off the shelf" guitar amp PS will give you the 320vdc, the bias voltage.  The +/-17vdc would have to be part of whatever PT you'd select.
The problem is,
what's your skill set?
how much room in the amp?
what's the amps "Load"?
is it even worth the trouble?
and
and
so many questions
Post by: mgalicki on February 24, 2024, 10:37:22 pm
is the pt part of this PS 320VDC? WHAT'S AMP LOAD? the watts? 33 watt amp 4 el34 tubes
