Other Stuff => Buy - Sell - Trade => Topic started by: jessetrbo on February 26, 2024, 02:16:54 pm
Greetings:
I need to purchase a filter capacitor cover (aka capacitor pan, aka doghouse cover) for a 1978 Fender Twin Reverb. It’s the 130w model and has extra filter caps… which makes finding a cover impossible.
The measurement for screw holes on center is approx 8 1/4”. The more popular size is a full one inch smaller.
Thanks for your consideration!
If you can't find a used one on reverb/ebay then it is possible to get one bent form sheet metal to your specs.
I hope you find it pre-made. Otherwise:
If all the other dimensions are the same, slice and stretch. Either get two and cut an end off each one, or get one, cut, and bend up a 1" scrap of steel to weld in. If you have a regular car mechanic, he can probably do it for a few bucks.
Go to a very fancy baking-supplies shop and look at little breadpans.
"...mini loaf pans that measure around 5 x 3 inches (13 x 8 cm),"
https://www.walmart.com/ip/HONGBAKE-Mini-Loaf-Pan-for-Baking-Bread-6-x-3-3-x-2-In-Nonstick-Small-Bread-Tins-Set-of-3-Tiny-Carbon-Steel-Meatloaf-Pan-Dark-Grey/5046344119
https://www.target.com/p/cuisinart-4pc-mini-loaf-pan-set-cmbm-4lp/-/A-81615559
https://www.target.com/p/fat-daddio-s-anodized-aluminum-bread-pan/-/A-89145147
https://www.goodcook.com/goodcook-premium-nonstick-steel-mini-loaf-pan-5-75-x-3-gray.html
Any medium city has HVAC duct makers, basically metal-benders. If you can fold it in paper, they can brake it out of scrap sheet; some may have dies to stamp like Fender. Here's one in my general area (my guy doesn't do websites):
https://www.twincitysheetmetal.com/Services/Ductwork/
(https://www.twincitysheetmetal.com/images/ductwork/middle-01.jpg)
If you can whittle or route a wood pattern, male or female, you can knock it out yourself. Use a ballpeen hammer, or a cut of broomstick, dowel, or oak branch, rounded.
Take a day in the junkyard. Some auto-modules are almost cheap enough to re-purpose. Ford made an over-designed ignition which failed a lot, so I used to have a pile of dead ones, but also demand kept new-price down.
Standard Motor T-Series Ignition Modules LX203T $33.99
https://www.summitracing.com/parts/smp-lx203t?rrec=true
(https://static.summitracing.com/global/images/prod/small/smp-lx203t_s.jpg)
The "potting" was pretty cheesy, throw in bonfire and should burn out.
Thanks for the good suggestions… cutting the smaller on in half and modifying is pretty ingenious.
I use https://seasidechassisdesign.com (https://seasidechassisdesign.com) exclusively now.
Very reasonable prices and his chassis's and doghouses are works of art.
Obviously, if you have a local fabricator, that's best.
Did you resolve this? If not, I would just use smaller capacitors and predrill for the largest doghouse you can get. F&T are much smaller than the originals, and the recently introduced Mojotone caps are super small. All work fine in my experience.
