Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: joesatch on April 05, 2024, 03:24:44 pm
do led diodes cause noise?. i use these indicators for channel switching. i have one close to the master and gain pot. they are dc powered so i assume they could cause noise? use coax shield on them? move them?
I don't hear any noise. Do you?
"noise" is typically AC, in the air, riding on a DC potential, even through "ground"
the only noise I would expect from an LED is at switch on/off and that would be measured in micro-seconds, way way outside audio.
ok so no noise should be expected. this sits well with me :l2:
Any diode will show a small transient when switched on or off. These are really really short (microsecond) transients, far beyond the bandwidth of a tube amp.
For channel switching, they would usually not be in the signal path, and would not be a factor. Theoretically, the transient could produce EMF, but IMO it would be so small that you could never detect it.
Some folks use LEDs to bias pre-amp tubes, and when I tried it got good results with no noise.
Too much blabbing. It's more of a theoretical issue than a practical problem.
It's kinda like that tree thing. A tree falls in the forest, but you didn't hear it. So, did it really fall? :l2:
