Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Colas LeGrippa on April 26, 2024, 11:12:47 am
Hi my friends,I plan to build a Fender external reverb unit and I am wondering if I can substitute the 6k6gt tube for another one (eg 6V6gt) with the same efficiency.
Thanks for comments
Colas
yes
https://el34world.com/Hoffman/files/Hoffman_6G15.pdf
Could you add tremolo with this 6AV6 circuit based on Rob Rob's 1/2 tube circuit? I have been thinking about building one but I would like tremolo too.
Yes, and decrease the cathode resistor for the 6V6 (1k is way too cold).
Do I have the pinout right for the 6AV6?
If you are dreaming of adding tremolo, take a look at Hoffman's Revibe.
Ok thanks
1K works very well in Revibe
1kΩ works very well in the original 6G15 reverb units.
They don't need "max power output" (1 watt +/- is good enough), and they need to not-distort even on strong signals (the schematic shows 24v of bias).
