Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: astronomicum on June 20, 2024, 05:21:25 pm
Title: UX-1501 Output Transformer Impedance
Post by: astronomicum on June 20, 2024, 05:21:25 pm
This amp is four tubes using 6550s. I have seen this model labeled 4-8-16, and 2-4-8 ohms on the impedance selector. The unit I am working on measures 5595, 5080, and 4956 ohms, labeled 4-8-16 ohms respectively. They should be about half that for 4 tubes. I think this selector should be labeled 2-4-8 ohms. Is this correct? Thanks.
Title: Re: UX-1501 Output Transformer Impedance
Post by: tubeswell on June 20, 2024, 06:45:14 pm
All depends on the Pri:Sec turns ratio (or squaring that to get the Pri:Sec impedance ratio)
Post by: sluckey on June 20, 2024, 06:46:49 pm
Is this DCR? Be specific. What measures 5595, 5080, and 4956 ohms?
Post by: astronomicum on June 20, 2024, 07:12:46 pm
Sorry. Here are the data and calcs:
The 4 ohm tap measures 37.4 turns, squared, times 4 = 5595 ohms
The 8 ohm tap measures 25.2 turns, squared, times 8 = 5080 ohms
The 16 ohm tap measures 17.6 turns, squared, times 16 = 4956 ohms
Post by: tubeswell on June 20, 2024, 07:19:42 pm
Doesn’t sound right.
Where did you get the information on the secondary turns? And what about the turns on the Primary?
Post by: astronomicum on June 20, 2024, 07:29:40 pm
Sorry. Here are the revised data and calcs:
The 4 ohm tap turns ratio measures 37.4:1, squared, times 4 = 5595 ohms
The 8 ohm tap turns ratio measures 25.2:1, squared, times 8 = 5080 ohms
The 16 ohm tap turns ratio measures 17.6:1, squared, times 16 = 4956 ohms
Post by: tubeswell on June 20, 2024, 09:58:47 pm
Well, if your information about the OT turns/impedance ratio is accurate* a 5k reflected load is ok for a PP OT for 2 x 6550s. You want 1.75k to 2.5k plate-to-plate load for a quad.
https://frank.pocnet.net/sheets/127/6/6550.pdf (https://frank.pocnet.net/sheets/127/6/6550.pdf)
(*But still not certain about where you got the turns ratio information. Do you have a schematic or spec sheet for the OT? Or did you measure actual Primary and Secondary VAC to work it out?)
Post by: astronomicum on June 20, 2024, 10:46:04 pm
Thanks for the confirmation. Yes. I test using VAC to determine the ratio. I collect this data. In this case, it also confirms this amp is not labeled correctly.
