Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: dwinstonwood on July 19, 2024, 01:54:17 pm
Title: 7C5 Idea
Post by: dwinstonwood on July 19, 2024, 01:54:17 pm
Hello all,
I've been buying some "oddball" NOS RCA tubes lately, and I have enough to string together.
This idea I came up with is probably more complicated than it needs to be, but it uses the tubes I've gathered so far.
Let me know what you all think. Maybe certain tubes would work better in different places.  :dontknow:
Title: Re: 7C5 Idea
Post by: passaloutre on July 19, 2024, 02:51:18 pm
I just finished a 5E3 with all Loctal tubes, including 7C5. It sounds great, I say go for it!
Title: Re: 7C5 Idea
Post by: bmccowan on July 19, 2024, 03:01:34 pm
I love doing things with different tubes. I have not used 7C5s yet, but I have a Masco amp waiting in the wings that has a pair. The other tubes I have used with success.
I do not like high gain amps - so my comments are colored by that.
It looks like a lot of gain to me. And if you end up taming the gain you still have the noise from an extra tube. I'd suggest a socket for one 7 pin preamp tube - and swapping the 6at6 and 6av6 depending on mood. Then I'd consider moving the 5879 to V2, I've used it a lot in that position. And then the 6SL7 as the PI. From what I have read, the 7C5 is a Loctal 6V6.
But mostly i want to spectate and see what you come up with. :icon_biggrin:
Title: Re: 7C5 Idea
Post by: Latole on July 20, 2024, 10:05:11 am
Hello all,
Nice schematic you post.  It is the first time I see those tubes
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 20, 2024, 11:42:47 am
Thanks you all! This is still at the brainstorming stage. I haven't even started planning a layout.
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 21, 2024, 07:38:02 am
I like using PSUD2 to play around with dropping resistors and to get an idea of B+ voltages. I entered the Hammond 270CAX specs from their datasheet and the plate currents from the various tube datasheets.
The 270CAX is rated at 250-0-250 with an 81mA load and has a 170.4mA max rating. I came up with a total of about 109.7mA, so I think this PT will work.
If my calculations are close, the screen voltage on the 7C5's should be around 264VDC. The 7C5 datasheet max is 285.
https://www.hammfg.com/files/parts/pdf/270CAX.pdf?v=1697661948
[edited to correct numbers]
Title: Re: 7C5 Idea
Post by: passaloutre on July 21, 2024, 09:51:06 am
They are 6V6GT tubes with a different base. They can take higher than data sheet voltages. Certainly anything you would subject a 6V6 to.
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 21, 2024, 03:00:26 pm
Thanks passaloutre! I've read that in practice these older tubes are usually rugged enough to handle higher voltages. Fender definitely knew they could.
But, I already have a 270CAX, and for me it's a fun challenge to try and design a power supply that meets those datasheet recommendations. I also like the sound of power tubes at lower voltages. My last amp - based on the Valve Wizards medium-gain design - uses 6V6's with 350VDC on the plates. I think it sounds great as a home-use amp.  :icon_biggrin:
David
Title: Re: 7C5 Idea
Post by: DummyLoad on July 21, 2024, 05:07:13 pm
Use a 7F7 in place of 6SL7/6AT7/6AV6 - Same electrically as the 6SL7. Use 7C7 in place of 5879 - Now is all loctal.  :icon_biggrin:
B+ node D - Decouple 5879 from that gain/CF stage with it's own R/C network, or likely will be very unstable with that much gain on tap. Sandwiching 5879 between the 6SL7 halves is going to be interesting. 470K grid stopper for 5879 is going to shave off a LOT of HF. Looks like you're building an SLO-ish OD channel amp with SLPI?
Just my 2¢  :icon_biggrin:
--Pete
Title: Re: 7C5 Idea
Post by: DummyLoad on July 21, 2024, 05:09:52 pm
Are you SURE you want .022uF bypass caps for 6AV6/6AT7 gain stages?
--Pete
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 21, 2024, 08:02:25 pm
Thanks Pete! Those bypass caps must have been a "copy/paste" mistake.  :icon_biggrin:
They should be 22uF or simply un-bypassed. Thanks for spotting that.
I originally had the 6AT6 as the Cathodyne (SLPI), and the 6SL7 as the Gain/CF stage. At some point I switched it up; not sure why. I've never used a 5879 before, so I just guessed on the grid stopper.
As has been suggested, it might make sense to just drop the first gain stage. I could then use it's B+ node ("E") for the 5879.
I appreciate the advice!
David
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 21, 2024, 08:26:36 pm
Here's version II with one less gain stage and the pentode decoupled.
Merlin states anything up to 1M can be used as a CF grid stopper, it simply increases soft clipping, and decreases headroom. I don't know what using a 500K pot as a Gain control/grid stopper will do, but it could be interesting to try!
Title: Re: 7C5 Idea
Post by: bmccowan on July 21, 2024, 09:11:57 pm
That's looking pretty Matchless Clubmanish. A great amp.
I built an all octal 6V6 Clubman - one of my favorites (I have lots of favorites :icon_biggrin:)
Title: Re: 7C5 Idea
Post by: passaloutre on July 22, 2024, 04:36:05 pm
--Pete
That’s what I did for my 5e3
Title: Re: 7C5 Idea
Post by: Glenn on July 23, 2024, 08:46:34 am
Hi bmccown. you have a pdf or like of this schematic, I
Can’t get Jschem to work on my iPad….. thanks
Title: Re: 7C5 Idea
Post by: bmccowan on July 23, 2024, 12:20:10 pm
Looking - if I don't find one I will convert the sch file.
I think this is the same.
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 23, 2024, 04:44:25 pm
I did some searching, and the 5879 has, in fact, been successfully used as a CF driver.
And, the 6SL7 datasheets say it is well suited for PI duty.
This is version III:
Title: Re: 7C5 Idea
Post by: Glenn on July 23, 2024, 05:34:12 pm
Thanks bmccowan I been wanting to build an all octal amp, I have all the stuff I need.
Dwinstowood, I built a Marshall super lead with 6aq5’s, these are 7 pin power tubes. I love this little amp a lot
Title: Re: 7C5 Idea
Post by: bmccowan on July 24, 2024, 06:15:31 am
I have a small Epiphone amp with 2x6aq5. I removed the "T filter" from that amp and it sounds great beyond expectations.
Octal preamp tubes are under-appreciated nowadays. I became fond of them while rebuilding old Gibson and Valco amps before they became darlings of eBay, and also repurposing old PA amps as guitar amps. I have never found octal preamp tubes to be particularly microphonic, but I do not build high-gain amps, so  :dontknow: And if you are old and arthritic like me, it's a lot easier soldering those octal sockets. :icon_biggrin:
It's fun to convert 9pin tube preamps to octal, but there are also tons of Valco and Gibson schematics (with a variety of head scratching mistakes) available.
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 24, 2024, 07:23:28 am
OK, now you all have got me looking at Octal preamp triodes.
Here's one that looks similar to half of a 12AX7 with a mu of 100:
https://frank.pocnet.net/sheets/049/6/6SF5.pdf
Title: Re: 7C5 Idea
Post by: bmccowan on July 24, 2024, 09:37:42 am
6sf5 works fine. I have had it show up in some really early Valco amps - and I think I have an early Gibson with that tube.
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 24, 2024, 09:55:32 am
And the 6SF5 "GT" glass versions are pretty cheap! I'll save the little 6AT6 and pick up a the Octal.
Anyway, this project is all about trying new/different things for fun.  :icon_biggrin:
Thanks.
Title: Re: 7C5 Idea
Post by: DummyLoad on July 25, 2024, 02:47:16 pm
ThreadJack - Ugh! My apologies in advance - Years ago, I experimented with an all octal amp - Deluxe-lsh if you will, the second channel being a pentode. ALL tubes were wrapped in metal, including the rectifiers. I used 6SF5 for the triodes, 6SJ7 for the second preamp channel, a pair of 5T4 full wave rectifiers, and 1614 for the final stage. Killer sounding amp, but never put to a chassis. The DC filaments were more trouble than they were worth, yes it was a bit quieter with DC to the preamps, but overall not worth the added expense and effort. The second schema is/was a much more recent revisited concept I dubbed "Rock'in Rosie Riveter", a Fenderish Super R with all octal tubes, so if Rosie rocked a roadhouse during WW2, she'd have that amp.  :icon_biggrin:
--Pete
Title: Re: 7C5 Idea
Post by: bmccowan on July 25, 2024, 03:59:00 pm
Hey Dummy...
Those are both pretty cool and imaginative. In Metal Mania I like the idea of being able to mix the pentode and triode preamps. I had trouble with that when I tried to mix 6SJ7 and 6SL7 channels, but I admit that I got distracted by another project and set it aside before finding a sweet spot. Did you find you could mix the channels and get an interesting tone, or did you just favor one channel at a time?
Also - amp chasses never finding their way to a cabinet is an issue I am very familiar with. :icon_biggrin:
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 25, 2024, 06:55:29 pm
Thanks for posting the schematics Pete. This thread can become a collection of Octal preamp designs as far as I'm concerned.  :icon_biggrin:
The 6SF5GT is an interesting tube. I've been trying out a bunch of different bias settings using various plate resistors, 250V B+ and -1.5 grid volts. The smaller resistors push the quiescent plate voltage pretty far to the right. Here are two:
Title: Re: 7C5 Idea
Post by: DummyLoad on July 27, 2024, 01:43:03 am
Treat the 6SF5 like a 12AX7, differences are minor, e.g., slightly less transconductance and slightly higher plate resistance. Have a look at the 6F5 resistance-coupled amplifier charts, they are same electrically. RCA Edition 16 Resistance-coupled Amplifier Charts for 6F5 & 12AX7 families attached to this post for comparison and guidance.
--Pete
Title: Re: 7C5 Idea
Post by: DummyLoad on July 27, 2024, 02:20:28 am
I had trouble with that when I tried to mix 6SJ7 and 6SL7 - Did you find you could mix the channels and get an interesting tone, or did you just favor one channel at a time?
The MetalMania was basically an all octal Matchless DC30 of sorts, you used one channel or the other. Mixing the two as I recall, was not a pleasant experience.
Around 2012 I built a Fender Deluxe 5E3-like into a Webster Electric PA - That amp does mix triode/pentode as the 5E3 does with triodes only, amp has seriously good tone, you should revisit that. Use a 6SJ7 with Matchless DC30 EF86 values and similar preamp B+. There is a thread on the forum about it - Schematic attached to save some search time. The only things I would do differently would be to ditch the x-line Master Volume and decouple the pentode power from the triodes power rail.
--Pete
Title: Re: 7C5 Idea
Post by: bmccowan on July 27, 2024, 07:36:16 am
Thanks Pete,
I like that schematic. If I did not repurpose that chassis :dontknow: I will take a look at revising that project. I have several solid old 6V6 and 6L6 Stromberg-Carlson/Bogen/RCA PAs waiting for winter projects. That schematic will go in my potentials file.
I rebuilt a Webster organ amp into a Gibsonesque amp a while back. That Webster has seriously nice iron.
I also built an octal Deluxe many years ago 2x6SL7, 2x6V6. It'd be fun to change one of those channels to pentode.
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 27, 2024, 08:49:04 am
Thanks for posting the Western Electric file Pete. I wasn't really aware of the 6SJ7GT pentode. Using that tube would make my preamp all-octal. So, I lifted it from your schematic!  :icon_biggrin:
And, also, thanks for those RCA charts. I more or less center-biased the 6SF5GT at -1.5V.
Title: Re: 7C5 Idea
Post by: bmccowan on July 27, 2024, 09:17:23 am
DW - the 6SJ7 is available both as a metal tube and GT. They perform the same as far as I have experienced.
EF86 and 5879 are quite similar electrically.
Anyways - you will find that Pentode in many Gibson and Valco schematics, as well as a few early Fenders.
They were used a lot in early PAs. People complain that they are microphonic, but I have not found them to be troublesome. Some prove this by tapping them with a pencil - to which the solution is - stop tapping your tubes with pencils. :icon_biggrin:
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 27, 2024, 09:29:18 am
Thanks bmccowan. I will definitely browse through those older schematics to see how they were used. And, yes, I noticed in Pete's schematic that he has pin-1 grounded, i.e., the non-G(lass)T metal-envelope version.
Since I already bought two NOS 7C5's and some nice NOS Cinch Loctal sockets, I'm going to stick with those.
I've gotten a lot of great info from this thread, so far.
David
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 27, 2024, 09:54:16 am
...and decouple the pentode power from the triodes power rail.
--Pete
Question: Is it OK to have the CF and its driver fed from different B+ nodes as long as the supply voltage is the same? I'd like to de-couple the 6SJ7GT in my schematic.
This Star Network is straight out of Merlin's Power Supply book.
Thanks.
[edited to fix schematic error]
Title: Re: 7C5 Idea
Post by: DummyLoad on July 27, 2024, 09:25:21 pm
--Pete
Thanks.
Yes to decoupling pentode from CF. You're missing a cap from 6SF5 plate to volume control.
--Pete
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 27, 2024, 09:35:01 pm
...You're missing a cap from 6SF5 plate to volume control.
--Pete
Yikes! Thanks for spotting that. I updated the schematic in Reply #31.
Title: Re: 7C5 Idea
Post by: DummyLoad on July 29, 2024, 02:44:17 pm
I see another issue with that plan I missed - The master volume control ties to a 1MΩ to ground, that's going to upset the bias of the SLPI. Consider another plan: Delete the 1MΩ, or insert a coupling cap between the treble pot wiper and the top of volume control.
Also, IMO it would sound/work? better with a 6SN7 LTPI to help recover some of the losses of the CF, the tone stack, and the SLPI as basically there are three consecutive elements of signal loss, the last bit of gain is about 10 and is the output stage itself.
Respectfully,
--Pete
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 29, 2024, 03:31:34 pm
Thanks Pete. I've actually been thinking about ditching the CF and moving that 1/2 of the 6SL7 over to the other side of the James TS as a recovery gain stage feeding the SLPI.
If the James TS is a bad load for a pentode I can go with a six-way cap selector switch instead. That's what I have in my AC15 and it works great (thanks to sluckey for that circuit).
I've drawn something up along those lines. There are probably errors:
Title: Re: 7C5 Idea
Post by: DummyLoad on July 29, 2024, 05:12:17 pm
Actually, I believe that the switched coupling cap ckt. was an Orange implementation in the 70's, later Matchless copied it, slucky took from both in his Dual-Lite and others?
Leave the CF, IMO it adds a lot to the overdrive character. replace the 1/2 of the 6SL7 with another 6SF6 for CF duty, use the 6SL7 or a 6SN7 as a paraphase/floating paraphase, LTPI. or Gain/Concertina pair.
--Pete
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 29, 2024, 07:07:13 pm
OK, this does make a lot more sense. Thanks.
Title: Re: 7C5 Idea
Post by: DummyLoad on July 31, 2024, 08:25:55 am
IMO, yes, but you should really create what you think you'd like  :icon_biggrin:   Those are some odd values for james stack, but then again, not my taste in tone. I do prefer the Ampeg V4/VT40 james stack values for guitar, again, just my preference.
Respectfully,
--Pete
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 31, 2024, 09:15:00 am
Thanks Pete. I think I got those James values out of Merlin's book.
There's also that TSC in the web (https://www.guitarscience.net/tsc/james.htm#RIN=38k&R1=100k&RB=1M&R3=10k&R4=180k&RL=1M&RT=470k&C1=470p&C2=4700p&C3=330p&C4=3300p&RB_pot=LogB&RT_pot=LogB) site where I got some earlier values.
I'll look at those Ampeg V4/VT40 TS values, too.
Title: Re: 7C5 Idea
Post by: dwinstonwood on July 31, 2024, 03:56:47 pm
It took some searching to track down the Ampeg TS values because they were originally on a small module board, and not designated on the schematics I looked at.
This image is the James TS with Ampeg values, but I lowered the 120k resistor between the pot wipers to 68k. This puts the bottom of the mid scoop at 500Hz which is the same frequency as the Fender TMB scoop.
At any rate, when I build, I'll start with these values tacked in.
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 04, 2024, 08:55:52 am
I think I can put the tone stack on the pots.  :think1:
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 05, 2024, 04:49:59 am
On some subconscious level I had to have been aware of this. Funny that it just struck me.  :laugh:
https://el34world.com/charts/Schematics/files/Fender/Fender_bassman_5f6a_schem.gif
But, I doubt that my project will sound too much like a 15W Bassman.
Title: Re: 7C5 Idea
Post by: glass54 on August 05, 2024, 06:46:11 am
Hi dw,
:thumbsup: I have done exactly that in a recent project and actually used the same RC values, Made the TC a "3 terminal network" can be changed anytime without adjustments to turret/terminal board  :laugh:
Also can do a Fender TC substitution easily.
Regards
Mirek
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 05, 2024, 03:40:19 pm
Thanks Mirek, I'd like to see a photo of that!
Here's a starting point. I'm going with the Star B+ supply. I've never used it before, but it's supposed to offer better decoupling at the expense of some ripple filtering. Although, I could increase the filter cap values. I'm just keeping the reservoir (not on the board) at 16uF because of the NOS 5Y3GT.
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 10, 2024, 07:41:44 am
I think I've finished my drawings (PDF below). The layout is intended for a blank JTM45-type chassis. But, the controls are left to right like a Fender.
I'm going with these Hammond parts:
PT 270DX: https://www.hammfg.com/files/parts/pdf/270DX.pdf?v=1697661948
OPT 1751M: https://www.hammfg.com/files/parts/pdf/1751M.pdf?v=1697661946
Choke 194A: https://www.hammfg.com/files/parts/pdf/194A.pdf?v=1697661947
Title: Re: 7C5 Idea
Post by: kagliostro on August 10, 2024, 11:05:19 am
Ciao Dwinstonwood
Very nice project, I like it, only regret I've no 7c5 tubes
If I can permit me to say my 2c
Why your choice for the PS node was to use the path of the old VOX AC30 ?
Also VOX in later models preferred to have the PS nodes "in series" instead of "in parallel", that way you don't use the ripple reduction due to the previous node filter
p.s.: Beautiful layout  :thumbsup:
Title: Re: 7C5 Idea
Post by: mresistor on August 10, 2024, 12:45:15 pm
Ciao Kag   he explained his reasoning for supply configuration in reply #44.
Title: Re: 7C5 Idea
Post by: kagliostro on August 10, 2024, 03:44:58 pm
May be I'm short-sighted, I don't see much advantage on using that configuration  :dontknow:
Talking about 5Y3 tubes as far as I can know a 30uf e-cap can be used without problems, despite what is written on datasheet
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 10, 2024, 06:37:46 pm
Thanks Franco! I've never used the Star filtering arrangement before, so I want to give it a try. I want to see first hand how it works out. It is described as being better at decoupling the stages.
Having said that, I have a lot of confidence in the grounding scheme I'm using - which I've arrived at from following the advice of others. I've used it in three previous amps and they all have no audible hum.
I've haven't bought any caps yet. Yes, I did pick 16uF for the reservoir because of the 5Y3GT datasheet, but if they typically tolerate higher values I can go with 32uF:
https://hoffmanamps.com/MyStore/perlshop.cgi?ACTION=enter&template&thispage=Capacitors&ORDER_ID=!ORDERID!#:~:text=32uf/32uf/500v%20FT%20multi&text=Multi%20Section%20Capacitors%20and%20Clamps
If the Star arrangement doesn't work out, there's no major surgery involved in converting to series filtering; I won't have to move or add turrets. It will just look a bit weird.
Thanks,
David
Title: Re: 7C5 Idea
Post by: DummyLoad on August 10, 2024, 08:56:22 pm
I have used 40uF with 5Y3GT in several applications without any issues, but note I was only using NOS rectifiers. The 32uF/32uF 500V F&T or J&J would be a good choice for this application.
--Pete
Title: Re: 7C5 Idea
Post by: kagliostro on August 11, 2024, 01:33:02 am
As I told there were AC30 that used that arrangement but in later models VOX swapped to a more usual "in series" arrangement
If there is an advantage in the use of the "parallel" arrangement is that the math to calculate the resistor value of the filter Is semplified as you know for each filter the input voltage
Your sperimentation  Is interesting and I'm interested to know your opinion on the result
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 11, 2024, 05:16:18 am
Thanks Pete. I'll also be using a NOS 5Y3GT.  :icon_biggrin:
Thanks Franco, I'll be posting results for sure!
Added updated drawings with larger filter caps and board drawings now on 8.5'' x 11" sheet:
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 28, 2024, 08:16:08 am
Well... this project is on indefinite hold. I was getting ready to order parts and started thinking about the fact that none of the amps I've build have reverb, and the only two that have tremolo use the bias-wiggle type.
So, I'm going to build a Revibe instead.  :icon_biggrin: I'll get a lot more use of that than building yet another amp.
Thanks for all the input, help and suggestions on this 7C5 project. I did complete the drawings, and I fixed the pot wiring in the layout - they were wired backwards in the previous drawing.  :w2:
I'm sure I'll start a new thread since I know I'll have questions...
David
Title: Re: 7C5 Idea
Post by: kagliostro on August 28, 2024, 10:29:35 am
Ciao Dwinstonwood
What about a Revibe/Herzog/Mini Amp ?  :icon_biggrin:
p.s.: For the Revibe give a look to the project of our friend Sluckey
Title: Re: 7C5 Idea
Post by: Willabe on August 28, 2024, 10:47:22 am
The revibe in not a bias wiggle tremolo. And it doesn't sound like a trem.
It's the Fender brown face amps trem/vibe. Has a different sound then trem or vibrato. Kinda in the middle? You really need to hear some clips of it if you haven't yet, before you build it. Guys argue over if it's just a trem or is a pitch shift vibrato.
Some love it, sluckey loves his. I'd build sluckey's if I built 1. All his documentation including layout and schematic drawings are below;
https://www.sluckeyamps.com/revibe/revibe.htm
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 28, 2024, 11:11:33 am
The revibe in not a bias wiggle tremolo...
Hi Willabe, yes I understand that the ReVibe has the 6G12 trem/vibe circuit. What I meant to say above was that the only two amps I've built with tremolo both have the bias-wiggle type, e.g., 6G3 Deluxe.  :icon_biggrin: I edited my post to clear up any confusion.
Title: Re: 7C5 Idea
Post by: kagliostro on August 28, 2024, 01:40:33 pm
Some time ago I had the idea to mix a Revibe (maintaining the reverb section) with Merlin's Vibrotron
https://ampgarage.com/forum/viewtopic.php?t=33565#p415161 (https://ampgarage.com/forum/viewtopic.php?t=33565#p415161)
But so far I haven't made it yet, even though it's still on my wish list
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 28, 2024, 04:22:58 pm
Thanks for that Franco! So, that's the circuit that Vox borrowed from Wurlizter?
Title: Re: 7C5 Idea
Post by: kagliostro on August 29, 2024, 01:03:35 am
Yes, that it is, don't remember if there are minor changes, on my PC I saved also some amazing samples, but at the moment it is broken
p.s.: note that Merlin used a 150V PT because he had it under hands, I think also a higher B+ can be used but don't know in wich way it will affect the tone
Title: Re: 7C5 Idea
Post by: murrayatuptown on August 29, 2024, 01:57:26 am
I bought a 7N7 cheap on eBay, then a 14N7 from same seller, ordered 10 Loctal sockets from China, then bought a lot of 7C5's, then enough Loctal sockets to feel safe(same number of sockets as tubes)...and realized the 7C5's were more used than NOS (there ARE some). I weeded out one that rattled when rotated, and one with corroded pins.
M
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 29, 2024, 07:03:53 pm
Thanks Murray. I've only been buying so called "NOS" tubes from sellers with 1K+ sales and over 98% positive feedback, free shipping and a free return policy. But that doesn't mean those buyers always knew what they got. It's possible that a never-used tube could have its silk screening rubbed off, but if it's been out of the box enough times for that to happen, then who knows if it's seen use or not? The good thing is that buying a "NOS" 6AT6 for $9 with free shipping from a seller as described above is not a big risk. That's a Chick-fil-A sandwich in the neighborhood where I work.
So, I've been listening to a bunch of 6G1X harmonic tremolo videos on YouTube today (at work). I have to have it.  :icon_biggrin:
Not mention, Fender tube-driven spring reverb. I'm surprised it's taken me this long to make this decision.
Title: Re: 7C5 Idea
Post by: Willabe on August 29, 2024, 09:58:37 pm
So, I've been listening to a bunch of 6G1X harmonic tremolo videos on YouTube today (at work). I have to have it.  :icon_biggrin: Not mention, Fender tube-driven spring reverb.
Now listen to the new Magnatone pitch shift vibrato, make sure it's the stereo vibrato. The mono's very good, but the stereo is just off the hook! It has this watery fluter sound from the sound going back and forth from 12" to 12" speakers.   :blob8:
Only thing that might be better is a real Leslie, but not a 2 speed Leslie, a variable speed Leslie. Yes they have those, I have 1. Speed is controlled with an expression pedal. The in between speeds sound much better for guitar than the standard 2 speeds that a Lesli has.  :icon_biggrin:
Title: Re: 7C5 Idea
Post by: dwinstonwood on August 30, 2024, 06:01:43 am
Thanks Willabe. I found this Brett Kingman video. That's an unbelievable effect.  :icon_biggrin:
I've always wanted to play through a Leslie. Listening to those Harrison recordings when I was a kid was what made me want to play the guitar. That sound is burned into my psyche. In the early 80's we would always go to see local Lindy Fralin and the Bopcats whenever they played. They had a Leslie cabinet; no other band in town did.
Title: Re: 7C5 Idea
Post by: kagliostro on August 30, 2024, 06:59:57 am
Real Leslie or .....
https://sluckeyamps.com/leslie/leslie.htm (https://sluckeyamps.com/leslie/leslie.htm)
this will be something you can duplicate
but, for  those who like to experiment the difficult way
(in procuring the components)
https://sluckeyamps.com/warbler/warbler.htm (https://sluckeyamps.com/warbler/warbler.htm)
Title: Re: 7C5 Idea
Post by: Willabe on August 30, 2024, 08:20:28 am
Bahhh, a Tele! No,no,no,no. Tele's to thin to hear the lushness of the vibrato.
Plug a Strat in! (Or buck clean.) You can't hear the watery flutter of the 2 speakers with the sound flipping back and forth on the video. He'd have to record it with 2 mics.
Lonnie Mac started the Maggie vibrato. And the 'whammy bar was named after Lonnie using a vibrato bar on his flying V in this song. After Wham came out everybody started calling it a 'wammy' bar.
Wham;
i=nUeQUus8EbP9tQi7
Slow blues with the Maggie vibrato. Stop;
i=BZSI9y_wgK4-ioHO
He has many other songs with the Maggie vibe on it, it was his signature sound.
Title: Re: 7C5 Idea
Post by: Willabe on August 30, 2024, 08:34:31 am
When we 1st heard Badge by Cream my buddies and I got hooked. But a Leslie was expensive AND heavy!   :laugh:  It's George on the bridge playing through the Leslie on Badge.
The 1st Leslie's only had 1 speed, later they went to 2, slow/fast. The thing with buying an old used Leslie is shipping.  :laugh:  I happen to find 1 a few years ago in about 8 out of 10 condition and it was only a few miles from me! The seller even dropped it off at my house!  :l2:
It was a single speed but I knew that there's a multi speed kit mod for those that uses an expression pedal. I installed the kit and with the pedal you can sweep the speed until you find what you like.
With a Hammond the 2 stock speeds sound fine, but with a guitar there's different speeds in between the slow/fast stock speeds that sound way better.
Title: Re: 7C5 Idea
Post by: Willabe on August 30, 2024, 09:23:57 am
The old Maggies weren't very road worthy.
Lonnie later used the Maggie preamp fed into a Fender BF Bandmaster head and separate speaker cab, a piggy back Fender.
Yes, I open up the head on mine, looks very strong to me. Their web site says 56lbs, I don't believe it, feels like more!   :laugh:  So I bought the piggy back model, costs more, but I can move it.
That used to be easy to move, but I'm older now.  :think1:
Title: Re: 7C5 Idea
Post by: glass54 on September 03, 2024, 05:22:46 pm
Hi dw,
From reply 44
Please see the TC caps/resistors on Pots. UGLY job much nicer with Fender TC (2 caps and 1 resistor).
All that aside, it does work well. (A couple dabs of "neutral cure" Silastic to stop components running away  :laugh:)
Regards
Mirek
Title: Re: 7C5 Idea
Post by: murrayatuptown on March 25, 2025, 04:48:20 pm
Thanks for posting that.
I have been buying small signal and some 7C5 Loctal tubes & have a 40's Zenith floor radio with the chassis containing a 7 Loctal tubes and PP 6V6 outputs. I don't need 7C5's for this, but plan to gut the radio parts & reconfigure the preamp. I have some Loctal pentodes I want to try as triodes. 14" field coil speaker.
I discovered Chinese loctal sockets are a disturbingly different animal so I've gotten several US-made ones which DO cost more.
Title: Re: 7C5 Idea
Post by: tubeswell on March 25, 2025, 07:56:34 pm
Late to party, but you might find values in this James TS give a flatter EQ response with T and B pots at mid-rotation - with pronounced hump with both pots cut and pronounced scoop with both pots dimed. Tried and tested (acknowledging that it all depends on the output impedance etc of the V1a stage)
Title: Re: 7C5 Idea
Post by: ALBATROS1234 on March 31, 2025, 12:20:03 pm
I have to go back and read through the progress of your build but to comment on the 7C5, I got a couple hundred NOS and used but good Loktals most of which I use on radio repairs, but I do have a handful or two of 7C5 and 7F7 NOS. These are said to be equivalent to 6V6's and 6SL7's but they seem to have a different tone. For instance, I made some 6V6 to 7C5 adapters using the bottom pin base of a Octal tube wired to a Locktal socket using a 1" EMT Coupling as the metal sleeve in which to mount them in fits perfectly. I also made a few 6SL7/6SN7 to 7F7/7N7 adapters. In all cases they sound noticeably crisper with more pronounced highs and upper mids and less noticeable lows. Not sure why this would be because to my knowledge most if not all Loktals were made by Sylvania so you would think this would be the guts of a Sylvania 6V6 in a glass envelope with a different type of base but, putting the same era Sylvania 6V6's and/or RCA's (which have slightly different flavors but are basically a similar sounding tube) then 7C5's with adapters in a PP 6V6 amp I found them to be not the same sounding tube at all. Not bad just different. Just saying you may need to tweak coupling cap values etc to make the circuit sound the same as an original 6V6 circuit as the 7C5's have this really crisp thing going on, not ice-pick but noticably different. The 7F7's are closer to the 6SL7's and tbh I almost like the 7F7's a little better(at least the few I have tried). Just thought I would detail my findings for those interested.
Title: Re: 7C5 Idea
Post by: dwinstonwood on April 01, 2025, 09:28:44 am
hello tubeswell and ALBATROS1234,
I never built the 7C5 PP amp. The project kept morphing and I ended up building this project. Of the eight tube guitar amps I've build since I started this hobby in 2020, this one is by far the best sounding of them all. It uses all NOS Octals.
