Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: plexi50 on September 18, 2024, 01:24:15 pm
This is a weird one. I have not been through this particular issue before with quick success. I have NO Oscillation in the Vibrato circuit. Replaced the usual 3 trem caps and roach.The roach lights up but that's it. I am using the foot switch which is part of the grounding for the Vibrato & Reverb.The foot switch is good and has no issues. The Intensity pot is good and is grounded.The volume of the amp drops a bit when increasing the Intensity pot. The Optocoupler light just stays on with no intensity.
Their is an older posting of this exact issue with a Twin Reverb but their was no answer. V5 is a new tube as i have tried many others.
Schematic? Voltages?
V5 Tube voltages. With Tremelo engaged. Pin 1 +410vdc - Pin 2 -37vdc - Pin 3 +3.26vdc - Pin 4&5 3.25VAC - Pin 6 +345vdc - Pin 7 +.035vdc - Pin 8 +10 vdc - Pin 9 3.25VAC. Optocoupler flashed weak 2 times and quit.
This model has the pull master switch.
What does the plate resistor on the oscillator triode measure? Seems you're about 110v too high on the plate based on the schematic (if I'm seeing what I think I'm seeing--copy fidelity is poor.)
Also your cathode voltage is very high compared to schem. Would be a good idea to measure the cathode cap and confirm bypass cap health.
My initial approach with trem issues is to replace the trem bias resistor with an LED, so you can at least see when the darn thing is oscillating!
Pin 2 -37vdc -
Does that sound normal to you? Because it shouldn't! Trem tube is stuck in 'off' mode. Your footswitch isn't working properly; maybe the footswitch jack has a bad ground connection. (Try shorting the hot wire to ground with an allegator lead to confirm)
I got it working. Changed out 5uf -50vdc cathode cap parallel to 100 K resistor and it started working. Foot switch is fine. I always use a grounded RCA plug instead of a foot switch.
