Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: rake on October 26, 2024, 11:41:40 pm
Guys After the input from my last schematic I tried to get closer to what I'm looking for.
I went over it multible times looking for errors but who knows??? LOL!
Any and all guidence is greatly accepted and appreciated! Thanks in advance!
Just suggestions to consider.
I think you're gonna need more like a 1M reverb pot if you have a lower value "mixing" resistor of 150k.
Treble cap in tone stack is 250p not .250p.
Overall not saying you "should" change what you've done, I'm simply offering how I would approach your idea.
Are the mains connectors in your region unpolarised?
If they are polarised, it's best to wire both the fuse and switch in the live feed.
If unpolarised, a double pole switch for both live and neutral, whichever way around they happen to be, is usually mandated.
Nicely drawn schematic!
Two thoughts.
I don't understand the function/effectiveness of the channel switching. What do you want the switch to do?
The Volume Pot location essentially duplicates the two gain pots. They vary the output of V1. I would enjoy hearing what effect you are seeking to offer alternative placements.
I have not used a 5879. I wonder if it might be better placed earlier in the circuit so it could have it's own volume pot.
The 5879 suppressor grid needs a DC connection, I think to its cathode is typical.
