Amp Stuff => DIY Layout Creator and Custom Boards => Topic started by: gjoslyn on October 30, 2024, 07:10:44 pm
Title: DIYLC and Mac OSX 15.1
Post by: gjoslyn on October 30, 2024, 07:10:44 pm
After installing OSX15.1 DIYLC would not open showing the message
The application "Finder" does
not have permission to open
"(null)".
To bypass the finder and open app you must use terminal.  Go to the DIYLC app and show package contents.  Open the MACOS folder and there will be a file there.  Drag it into a terminal window and DIYLC will open.
Title: Re: DIYLC and Mac OSX 15.1
Post by: wsscott on December 23, 2024, 03:16:05 pm
Didn't work for me.  Same error.
Post by: EL34 on December 24, 2024, 07:46:35 am
Probably the best place to ask these type of questions is in the top post link to Github
https://el34world.com/Forum/index.php?topic=23696.0
Post by: wsscott on December 24, 2024, 07:51:26 am
Thanks.  I'll check it out.
Post by: acheld on December 24, 2024, 10:17:41 am
DIYLC does run on Macs just fine.
BUT, over the past couple of years there has been an increase in security effort within MacOS, and with that a number of security changes that I have trouble remembering.  It's maddening.
The main thing is to in System Settings>Privacy and Security. From there, scroll down and make sure that under "Security" the button is checked to allow apps to run from the App Store and identified developers.
Scroll up and look in "Files and Folders" and be sure that DIYLC has access.  I normally give DIYLC "Full Disk Access" as well.
As I'm writing this, I'm on an older Intel MacBook.  The newer Apple silicon computers have similar, but nonidentical measures in place.   The ideas are the same, but the System Settings visuals and choices are different.
I haven't found Github to be particularly helpful in this situation due to the fact that the developers mostly run Windows, with Apple as an afterthought (if that!).
If the above does not work, post again and I'll see if I can walk you through the settings on a newer system.
Post by: wsscott on December 24, 2024, 10:35:39 am
Thanks.  I've done all that but still get this error message when I double click the App:  The application “Finder” does not have permission to open “(null).”
I'm running Sequoia 15.1.1.
Post by: martiro7 on January 09, 2025, 02:29:36 pm
This is a known problem. I downloaded the latest DIYLC and it does not work with the fix above. Go back to version 4.37.0 and this method will work (see attached screenshot.)
Post by: wsscott on January 09, 2025, 02:51:52 pm
Thanks.  I"ll check it out.
Post by: wsscott on January 10, 2025, 10:13:48 am
Thanks.  Its working fine.
