Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Snake5150 on January 20, 2025, 08:52:21 pm
Title: Noise on startup
Post by: Snake5150 on January 20, 2025, 08:52:21 pm
Jtm 45 new build
Was fine on limiter, installed power tubes. Went off limiter. Bias at -45vdc
The amp after 10-15 seconds develops a significant constant hum and reaches 20mv across the cathode resistor before forcing shutdown.
I’m very confused. I’ve checked wiring, nfb, bias and socket wiring.
Only differences I’ve made from original is the cap layout attached. Any help would be awesome .
Title: Re: Noise on startup
Post by: Latole on January 21, 2025, 03:36:30 am
20 milivolts across the 1 ohm resistors on each EL34 ?
Please be more specific.
Schematic of your build will be more helpfull than a layout
Your mod is the issue IMO
Why don't you build like the layout ?
Post by: Leevi on January 21, 2025, 04:40:58 am
A constant (loud?) hum indicates that there is some bad/broken contact in the circuit.
Try to isolate the problem to see if it comes from pre or power amp.
For instance short the treble pot wiper to the ground.
/Leevi
Post by: Latole on January 21, 2025, 06:15:22 am
In my opinion, it's a mistake to modify a new construction without making sure that the original version works properly.
Especially if you're not a “pro” in the field.
Then you can modify it.
Post by: Snake5150 on January 21, 2025, 08:47:05 am
I was told I can be problematic to have the cap after the standby switch. At this point I’ll prolly go back to original.
Post by: Latole on January 21, 2025, 09:17:22 am
You are right .
You may have a mistake somewhere. On your mod or elsewhere ?
Build like the original circuit, check all you wiring.
Make the amp playing first.
Post by: Snake5150 on January 21, 2025, 09:52:23 am
You are right .
I’m hoping it’s something to do with the fact my standby switch is not connected to the cap directly but to the rectifier dc out.
Post by: Willabe on January 21, 2025, 10:27:43 am
This makes no sense.  :dontknow:
It should be; rectifier > 1st B+ filter cap > stand by switch > 2nd B+ filter cap.......
Post by: Leevi on January 21, 2025, 10:42:41 am
https://www.valvewizard.co.uk/standby.html
/Leevi
Post by: Snake5150 on January 21, 2025, 10:46:15 am
Which is how the original basically layout has it. So basically all the internet advice led me astray from common sense.
The og layout shows rec to standby- out of standby to cap , otct, and choke , this then feeds the other cap correct?
Post by: Willabe on January 21, 2025, 02:09:03 pm
The og layout shows rec to standby- out of standby to cap , otct, and choke, this then feeds the other cap correct?
No.
Not rectifier to stand by.
It should be; rectifier > 1st B+ filter cap > stand by switch > after stand by switch take B+ to feed OT CT > choke > 2nd B+ filter cap.......
Post by: Snake5150 on January 21, 2025, 05:24:31 pm
No.
Like this?
Post by: mresistor on January 21, 2025, 05:35:43 pm
Like this
Post by: Snake5150 on January 21, 2025, 06:19:11 pm
Like this
Totally on me but can’t really decipher what the schematic is saying in relationship to my situation. There’s multiple parts labeled on the schematic that my rookie ness has no idea what they are.
I’m sure it’s annoying to some but I’m a super novice and am just trying to finish this thing.
I understand how the circuit chains together but when b+ goes to the 2nd cap, is this were otct and choke as well as the power tube pin 6 feeds come from?
Post by: Willabe on January 21, 2025, 08:45:10 pm
In the schematic mresistor posted, see where it shows TR2? That's the choke, just to the right, before the choke, just above, see +440dcv, that goes to the OT CT, and just to the left of the choke, where it shows B, there's the 2nd B+ filter cap and that's the screen grid B+ feed.
You really need to be able to read a basic schematic. And Fenders are about as easy as they get to read. And with that you really need to understand how a basic tube amp power supply works.
What this means is you need to stop taking short cuts and invest the time it takes to read up on these things if you want to be able to build and/or repair a tube amp.
I don't see how we can help you until you do some studying. You don't understand what we're saying and you don't understand the schematic.  :dontknow:
Start with this, here's the link to Rob Robinette, much of what you need to read is in here;
https://robrobinette.com/Amp_Stuff.htm (https://robrobinette.com/Amp_Stuff.htm)
Scroll down on any page in this forum and you'll see links that our host Doug posted that have lots of great information. Great information in here too;
https://el34world.com/schematics.htm (https://el34world.com/schematics.htm)
And this on servicing Fender amps is in the above link;
https://el34world.com/schematics.htm#Servicing%20fender%20amps (https://el34world.com/schematics.htm#Servicing%20fender%20amps)
And this is the link to Merlin's web page;
https://www.valvewizard.co.uk/ (https://www.valvewizard.co.uk/)
Post by: Willabe on January 21, 2025, 08:50:51 pm
Here's a full Fender schematic with a solid state diode rectifier. Maybe you can understand this power supply with stand by switch a little better.
The 1st filter caps, right after the rectifier and before the stand by switch, are stacked to get a higher voltage rating. Depending on your PT, you might only need a single cap there.
https://el34world.com/charts/Schematics/files/Fender/Fender_twin_reverb_ab763_schem.pdf (https://el34world.com/charts/Schematics/files/Fender/Fender_twin_reverb_ab763_schem.pdf)
Or, if you have a tube rectifier;
https://el34world.com/charts/Schematics/files/Fender/Fender_super_reverb_ab763_schem.pdf
Post by: Snake5150 on January 21, 2025, 09:15:05 pm
I’ll deff work on my schematic reading.
However after reading the valve wizard site
I’m hella dumb. It’s all right there
That’s also cool cuz I have a 74 super reverb never even thought about looking at a schematic for it
