Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Lectroid on September 04, 2025, 02:55:16 pm
Title: Deluxe 5E3 tone stack
Post by: Lectroid on September 04, 2025, 02:55:16 pm
I'm looking at rebuilding my Bell&Howell Deluxe-ish clone.  I built it with a standard 5E3 tone stack, with the interactive Volume and Tone controls.  But then I got to wondering:  What if the volume and tone controls were wired one after another, in series instead of in parallel?
Anyone know the reason the Fender 5E3 controls are wired together like they are?  What's the reasoning?  It seems like they might be separated into two consecutive circuits, but Leo Fender didn't and he must have had a reason.  Usually it was to save a few beans but I don't see any lower parts count no matter which way you do it.
Here's the original 5E3 Deluxe-like tone stack and the new separated method I'm wondering about.
Title: Re: Deluxe 5E3 tone stack
Post by: tubeswell on September 04, 2025, 10:15:10 pm
My reading of all the Fender amp typologies through the 40s, 50s and 60s was that Leo wasn't trying to make amps more distorted as he went along, he was trying to get them to sound cleaner.
The stock 5E3 effectively has 2 triodes 'in each channel' before the (unity gain) cathodyne stage - that is more than enough to drive a 6V6 grid to full clipping. If you make it three preamp triodes before the cathodyne, you will get even more distortion - which may well be your goal YMMV. (If you put a pentode in there - like you have in your schematic - even more distortion)
Post by: Platefire on September 04, 2025, 11:49:11 pm
If I remember correctly sluckey made the attached drawing to show how the normal channel interacts with the bright channel on a 5E3. If he sees thesehe may elaborate on it more.
Post by: kagliostro on September 05, 2025, 12:43:24 am
Only one consideration
A pentode has more gain than a triode but the signal loss Is higher if a pentode Is followed by a Tone Control than what happen to a triode
Post by: AlNewman on September 05, 2025, 01:16:32 am
Probably hard to say without a schematic as built.  I think the 5E3 works because the 2 input stages interact with each other.  If you only have 1 input into the same tone stack, you're probably missing half of the equation.
If you go to TSC, you can look at different options, I would think now you're closer to a princeton than a deluxe.  With one tone control and a volume out, the Framus looks interesting, as well as the Big Muff.
http://www.guitarscience.net/tsc/info.htm
Post by: Merlin on September 05, 2025, 03:00:09 am
With the original arrangement you get treble cut and boost (if the vol pot is not at maximum). But with your arrangement you only get treble cut, and also volume loss, so it's a less versatile configuration.
Post by: pdf64 on September 05, 2025, 04:34:19 am
With the original arrangement you get treble cut and boost (if the vol pot is not at maximum). But with your arrangement you only get treble cut, so it's a less versatile configuration.
Wouldn't there also be an inherent bass cut due to the 470pF cap feeding the tone pot?
Post by: kagliostro on September 05, 2025, 07:29:36 am
Don't know if this can be of your interest
(https://i.imgur.com/OOp4AIj.jpeg)
This is a 5e3 build from scratch that we planned few years ago at DIYItalia and was build by a friend with success
Note that each channel has its own Tone Control with different arrangement and values, channels can be joined at the input
p.s.: FXLoop was borrowed from one of the Mr Merlin's books
Post by: Platefire on September 05, 2025, 10:24:31 am
OK, I found it! sluckeys explanation on how the bright channel effects the normal channel as follows:
Assume no signal on the bright channel. The 'blue' indicates the normal signal path and the 'gold' indicates tone filters.
Look at Figure 1. The tone pot and .005µF cap form a variable series shunt filter connected directly between the normal signal path and ground.
Look at Figure 2. The bright channel volume pot and the 500pF cap interact somewhat with the normal signal also. Imagine the tone pot wiper at the top end of the pot and the bright volume pot at it's bottom end. The 500pF cap is shorted out in this case and it's effect on tone is minimal. Now crank the bright volume pot to the top and you will see that the 500pF is now connected directly between the normal signal path and ground, shunting some high frequency signals to ground. Moving the bright volume pot between extremes varies the amount of attenuation to the high frequencies, acting like a tone control for the normal channel. The effect is not nearly as noticeable as the real tone pot, but you can hear the effect.
Post by: Lectroid on September 05, 2025, 10:38:47 am
If anyone's interested, below is the full schematic of my amp as built
Leo ... was trying to get them to sound cleaner ... If you make it three preamp triodes before the cathodyne, you will get even more distortion - which may well be your goal YMMV. (If you put a pentode in there - like you have in your schematic - even more distortion)
I do like this amp because it slips so smoothly into distortion as I turn up the Volume past 4-5.  If that's due to the pentode topology, more power to it.  :laugh:  The design is 95% stock Bell&Howell projector amp.  I changed the originsal Tone circuit, to be frank, just because I couldn't understand it at the time.  Not sure I do do now, beyond it being a series of RC high-pass and low-pass filters to, I suspect, deal with a rather harsh operating environment inside the projector.  I know some guitarists revere the tone of the unmolested B&H and I sort of regret my noobish butchery.  But I'm happy with the result.
So--turning up the volume sends less and less signal through the tone pot, and send more signal to the grid of V2a.  I'd guess this also sends less signal through the Tone pot for filtering. So, in the standard 5E3 Deluxe, higher volume also comes with a lowered ability to control tone.
Why is that?  I think others here alluded to that also.
I like your schematic, with that interesting volume/tone arrangement.  Are the extra caps on the volume and tone pots put there to provide a "bright" option, like Fender did?  Only not on a switch, but controlled by a pot?
Everyone, thanks for all the discussion.  I've learned a few things.
Post by: kagliostro on September 05, 2025, 12:13:52 pm
Ciao Lectroid
When I've seen your first schematic with the pentode and the Tone Control I was in doubt if you  were using it only to show the kind of Tone Control you were interested to put on your 5E3 (with triode as V1) or to really build it that way with the V1 pentode
So I posted about the loss of signal if a pentode Is followed by a Tone Control
That happens because of the impedance of the pentode that Is loaded in an havvy way
Now accept it as is, don't remember at the moment the exact tenichal explanation, I learned this thing  years ago, because I noticed that only very, very few amps that has a pentode adopt a Tone Stack after a pentode and investigated
I'll go to reftesh my memory and say more later
If you are interested to see one of the few schematics with a V1 pentode followed by a Tone Control give a look to the Dr Z Route 66 schematic I attach here
The schematic I posted is a mix of mod we found on the web and mix together, years has past since there and don't remember the source of the double Tone Control arrangement, we were plagiarizers not engeeners
Post by: kagliostro on September 05, 2025, 03:58:17 pm
A triode has a relatively low internal resistance (ri) (on the order of tens of kΩ).
This makes it suitable for driving resistive/capacitive loads such as a tone stack, which is typically a passive attenuator with resistors in the 100 kΩ range and capacitors of various values.
A pentode, on the other hand, has a very high internal resistance (hundreds of kΩ up to several MΩ).
In practice, it behaves almost like an ideal current source, with very little ability to supply current to a “heavy” load.
A classic passive tone control (like            Fender/Marshall/Vox) has:
A typical working impedance around 30–50 kΩ at mid settings.
A signal loss of about 10–20 dB, even without extreme adjustments.
A strong dependence on the source impedance: if the driving stage has high output impedance, the tone stack becomes ineffective or alters the frequency response unpredictably
If you put it after a pentode, which has extremely high output impedance, what happens is:
The pentode cannot provide enough current to properly drive the potentiometers and capacitors in the network.
The tone stack heavily loads the anode signal gain collapses and the frequency response becomes unstable.
The result is a choked, unmanageable sound.
Post by: Platefire on September 06, 2025, 12:40:36 pm
Fun discussion! I find the tweed fender 5E3 and 5F2A tone stacks very interesting. They are so simple but can be very effective. On the old tweed amps just the raw signal sounds pretty good without anything added but are sometimes too dark, especially for humbuckers. So this tone stack can throw in just the right amount of sparkle into the mix as needed.
BTW--just a few simple changes, you could get your 5E3/5F2A tone stack back :icon_biggrin:
Post by: Lectroid on September 07, 2025, 01:44:08 pm
Franco, thanks for that great summary.  I still have trouble remembering how important impedance is, how many parts of the circuit it affects.  (everything?)   Your explanation made perfect sense.
It's true.  The 5E3 is so simple, it's like the one-celled organism of tone stacks.  But it works well in my Bell&Howell conversion and does add that sparkle you mentioned.
Post by: HotBluePlates on September 10, 2025, 06:54:13 am
... 5E3 tone stack ... I got to wondering:  What if the volume and tone controls were wired one after another, in series instead of in parallel?
Anyone know the reason the Fender 5E3 controls are wired together like they are?  What's the reasoning? ...
Get Way-Simple...
Look at the Volume pot on the Deluxe Reverb's (https://el34world.com/charts/Schematics/files/Fender/Fender_deluxe_reverb_ab763.pdf) Vibrato channel.  There's a 47pF "bright cap" wired between the Input and Output of the pot.
When you turn up the Tone control on any Fender single-knob Tone circuit (https://el34world.com/charts/Schematics/files/Fender/Fender_princeton_5b2.pdf), it is just a bright cap to bypass highs around the pot to make the sound brighter.  And then it has a cap on the other side of the Tone pot so you can also make the sound darker.  This is different from something like the Supro Spectator (https://el34world.com/charts/Schematics/files/Valco/Valco_510_11.pdf), which could only make the sound darker.
Look again at the Deluxe Reverb schematic:  there are 220kΩ channel-mix resistors right before the phase inverter input coupling cap.  Fender did the same kind of channel-mix resistors to blend channels on the brown 6G3 Deluxe (https://el34world.com/charts/Schematics/files/Fender/Fender_deluxe_6g3.pdf) right after the Volume & Tone controls.  In all the 1950s Deluxe variants, they had the bright idea to turn the Volume pots around so that the pots acted like their own "channel-mix resistors."  That created channel-/control-interaction, and apparently Fender chose to just spend the cost of 2 resistors to undo that by the 1960s.
I don't see anything "separated" but only a Tone circuit before the Volume control (though yes, I see you removed a connection between the 2).
What jumps out to me (aside from Merlin's point about the Tone control can now only remove highs) is the 470pF cap in series with the original 0.022µF coupling cap.  This is effectively "coupling caps in-series" and the total capacitance is smaller than the small-cap (here, it tallies up to about 460pF).  That arrangement will strip out all low end before the sound gets to the Volume control...
Post by: Lectroid on September 13, 2025, 12:29:59 pm
Get Way-Simple...
the Deluxe Reverb's (https://el34world.com/charts/Schematics/files/Fender/Fender_deluxe_reverb_ab763.pdf) Vibrato channel... a 47pF "bright cap" wired between the Input and Output of the pot
the Deluxe Reverb 220kΩ channel-mix resistors ....
That answers my question about Fender's thinking.  As tubeswell said, Leo was trying to clean up his amp' sound.  How to 'fix' that tone-stack's interoperability?  All these responses here proved that 1). my idea is definitely not the fix for it.  And 2) it has its own charms and admireres.
I don't see anything "separated" but only a Tone circuit before the Volume control.
That's all I meant to show--an illustration of "what if you put the two controls one after another, no longer in that Fender conjoined arrangement?"  My amp is much closer to the Bell&Holwell 179 circuit than it is to the 5E3, except I stole the 5E3 tone-stack (because it was quick and easy).  I'll attach the schematic below in case.
Impedance: how to recognize when to consider it's effects, and how to figure it.  How to look at a circuit node and parse out all the impedance-related interactions that can happen in all the interacting components between one signal-chain anode and the following tube's grid.  Those things are still blurry to me in spots, but all this has really helped. I learn a lot when I get so many different answers trying to explain the same thing. It's like triangulation.
What jumps out to me ... is the 470pF cap in series with the original 0.022µF coupling cap.  This is effectively "coupling caps in-series" and ... will strip out all low end before the sound gets to the Volume control...
Thanks for pointing this out.  I know enough about caps to know that I should have seen this myself.   :think1:
Everyone, thanks again!   :worthy1:
