Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: jukelemon on September 23, 2025, 04:31:51 pm
Hi all!
I have a MKIII with not only a complete lack of bias supply but adding insult to injury...a bias supply of 186vdc :)
I have attached the schem as well as points 1 and 2 on another attachment.
Amp had a burnt screen resistor on one of the 6CA7s. Repaired that and went ahead replaced all the screen resistors 5 watters for safe measure.
Bringing up the amp via a Variac I noticed a good NEG bias supply on the left pair but a climbing POS bias supply on the right pair.
So shut it down and remove the tubes.
In the middle of tracing the bias supply to Point 1 (on attachment), the left side pair goes positive as well :(
And by POS, I mean 180+VDC.
So... I can measure an expected -59vdc at Point 1 BUT when I cross the 220k resistors (Point 2), I get the 180+vdc bias supply and that follows on down to the pins.
So...I measure the .1 caps that are coming off the Phase Inverter. Both (odd I know) are shorted. I measure continuity between the leads on both.
So, I am assuming the shorted coupling caps are allowing DC into the bias supply and that is why I am seeing what I am seeing. Make sense?
On another note...i don't think the schem is written correctly because those .1 caps are not on the side of Point 1. They are actually on the side of Point 2 which makes sense as to what i am reading as far as component location/leads.
Boogies have a reputation for using under spec caps in this location. They're typically 400V where a 600V+ cap would be better. Replace with the equivalent value in a higher voltage and then check again with the tubes out. There's also a chance the filter caps in the bias supply were reverse biased if you had voltage leakage. You may need to inspect and possibly replace those.
Thanks. I have read that too and was planning on 600v caps for sure.
So....my logic is accurate then?
I traced the bias supply all the way from the PT so I am thinking I am good up to the junction of those .1 caps.
your logic is sound, redraw of find a better schematic though because the schematic makes your logical conclusions illogical :icon_biggrin:
this is one of their 50W make it look like that
Thanks Shooter and yes, that schem looks more like what I’m seeing in real life.
Of interest .. the schem I posted is identical to what came with the amp :) The original yellow documentation papers are still with the amp.
The schem also doesn’t show the 2.7k screen resistors on the 6ca7s.
Weird
In the event others are in a similar boat…c511 and c512 are the offenders.
Pulled them out today and both are dead shorts between leads.
I don't see them labeled on the schematics.
Which 2 caps do you mean? The power tube coupling caps?
Sorry. Yeah. The actual board is labeled in the amp. Why the schem is not and the board is .. not sure.
I’m referring to the the 2 x .1 caps off the PI and connecting to the bias circuit
Closing the loop...
2 x new .1 caps and the amp is back to life and healthy!
Can't say I like the sound of them and damn...how heavy can it get lol.
Out of interest, were the original caps only 400V rated?
Yes. 400v spec on the original 2 x .1uf orange drops
Why are 400v rated PI to power tube blocking caps getting killed in that amp?
The voltage across them at initial power up, for the 30ish seconds until the valves warm up and start to draw HT current, can be well above 400V.
eg 500V unloaded HT on one side, -50V bias on the other.
Ok, thanks.
The schematic in Doug's library for the MkIII shows a stand by switch. I know you guys don't like stand by switches but here seems it would stop the PI blocking caps from being eaten. Or like suggested, just use a 600v cap. But the amp has the switch already, just use it.
Ok, thanks.
Yes, there is a SB switch and it is my understanding that it is less a voltage issue than than not so great Orange Drop QC in the 80s AND the fact that they are 35+ years old at this point.
I don't know... :dontknow:
