Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: pbman1953 on November 30, 2025, 10:23:11 am
Is it enough to use a multimeter continuity test to test an inductor?
I have this Fender amp with 6 coils-
#1- no continuity
#2- 130 ohms
#3- 55 ohms
#4-32 ohms,
#5 -16 "
#6- 9 "
I have a feeling #1 is bad
Usually NOT
Obviously if It results open it is a bad thing
You require a specific item
Someting like this
www.ebay.com/itm/176909809975?_skw=esr+meter (http://www.ebay.com/itm/176909809975?_skw=esr+meter)
Those items measures also impedency
A question on the rebuild.
Should the v1B pin 3 resistor stay as is with the 1.5k or be replaced with a 680 ohm? I think on my last rebuild one of the forum members told me to do that
Any thoughts on my resistor question?
I don't see why it should be changed but you could use whatever value sounds good to you.
