Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Yosser on May 25, 2026, 09:19:38 am
Title: Biasing a tube amplifier with output tube anode resistors.
Post by: Yosser on May 25, 2026, 09:19:38 am
This might seem obvious, but are the anode resistors included with the secondary winding resistance in the calculation below?
https://robrobinette.com/How_to_Bias_a_Tube_Amp.htm
The amplifier I wish to bias has 22R resistors in series with the anodes.
Title: Re: Biasing a tube amplifier with output tube anode resistors.
Post by: mresistor on May 25, 2026, 10:13:27 am
I was thinking that you would have to subract the extra resistance somehow.   Probably should use and alternate method like a bias probe or 1 ohm resistors on the cathodes and then subtract a nominal screen current value out of the total tube current to arrive at plate current.      I asked AI
Post by: sluckey on May 25, 2026, 10:21:48 am
Much easier than AI's response...
All plate current must flow through the 22Ω resistor. So, simply measure the voltage drop across the 22Ω and do the simple math, I=E/R. Then multiply the resulting current times the measured plate voltage to get plate idle dissipation.
Post by: Yosser on May 25, 2026, 11:34:07 am
"measured plate voltage to get plate idle dissipation" is that the voltage measured at the anode or the voltage drop between the ct and anode?
Post by: sluckey on May 25, 2026, 11:49:11 am
"measured plate voltage" is the voltage between anode and cathode. If this is a fixed bias amp with cathode connected to ground, that would be anode to chassis ground.
Post by: Yosser on May 25, 2026, 12:14:26 pm
Ah, thanks
