Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: jukelemon on June 26, 2026, 10:13:51 pm
Title: Looking for amp ideas for a 5e3 chassis
Post by: jukelemon on June 26, 2026, 10:13:51 pm
Hi all. Hope everyone is well.
So.. I built a Proluxe head a while back to use with a touring Leslie. It works really well but I’d like to get more clean power and am looking at ideas as far as a new circuit but with existing PT and OT.
OT is a 40w Pro Reverb spec. PT is for a BF Bassman.
I don’t mind redoing the chassis labels so in essence I have three controls available and 4 inputs.
I thought about changing to fixed bias but in the past I really have not noticed a big difference between that and a cathode/bypassed power section with the same preamp design.
Thoughts?
Something to consider too .. I do not need a tone stack. The original Leslie amps just had a Volume control. Right now my tone knob is dimed.
Title: Re: Looking for amp ideas for a 5e3 chassis
Post by: jbrew73 on June 27, 2026, 04:24:21 pm
What about using the 6g5 or 6g5a pro power amp?
I would think the ltp phase inverter, negative feedback and fixed bias would give some additional headroom.
Post by: Adrien on June 28, 2026, 10:18:00 am
By Proluxe do you mean this?  https://robrobinette.com/images/Guitar/5E3P_Build/5e3p_Schematic_small.png  So basically a tweed deluxe with 6L6s.
Looks like you've got 2 preamp tubes and 2 power tubes, 3 controls to work with.  Fun project.
I agree with jbrew that stepping up to a brown/black panel bassman/pro style power section would get you more clean power.  My choice would be the normal channel of an AA864 Bassman: https://el34world.com/charts/Schematics/files/Fender/Fender_bassman_aa864.pdf
Compared to the 6G5 pro or 6G6 Bassman it doesn't have a presence control so that leaves just Treble, Bass and Volume which fits your chassis and would sound great with pretty much anything.
Or for something similar but a little more outside, you could look at a single-channel version of the Selmer Treble 'n' Bass 50, those are pretty cool: https://el34world.com/charts/Schematics/files/Selmer/Selmer_treblenbass_mkii_50w.pdf
Post by: jukelemon on June 29, 2026, 06:57:56 am
Very good ideas guys. Thank you!
I don’t have any of my board making tools any more. Is there any interest in making a board for that idea ie a Bassman normal channel only board? Fee based of course.
Post by: Rontone on June 29, 2026, 07:34:25 am
Doug has AA864 type boards, if you just leave the unused areas blank:-
https://hoffmanamps.com/MyStore/catalog/EyeletBoard.htm (https://hoffmanamps.com/MyStore/catalog/EyeletBoard.htm)
Or there is the custom board link at the bottom also...
Post by: dogburn on June 29, 2026, 08:36:13 am
You might look at Rob Robinette's Blackvibe layout - it's pretty much the same layout you would need, with just some minor differences (like it includes the bias circuit on the board rather than as a separate board, and it includes a coupling cap between V1b and the phase inverter). He includes a DIYLC file for just the board, and you could upload that and have Hoffman make the board.
Post by: Adrien on June 29, 2026, 10:41:16 am
Blackvibe is a great suggestion, it has the filter caps on the board and everything.  Doug already has the blackvibe boards ready to go: https://el34world.com/Forum/index.php?topic=24873.msg270122#msg270122
Note that the Hoffman boards are always 3-1/8" wide so depending on your chassis internal width Doug's boards may be a bit tight.  I would double check that first.
Also check out this layout from Sluckey, it's a narrower alternative that would fit great in your tweed chassis:  https://sluckeyamps.com/misc/AB763_Deluxe_Lite.pdf
You would just need to figure out where/how to mount the filter caps.
Post by: dogburn on June 29, 2026, 03:39:46 pm
I was thinking that the Blackvibe board would work for a single channel AA684 Bassman build, but the Blackvibe itself would certainly be a fun option.
Post by: jukelemon on June 29, 2026, 03:58:29 pm
Great ideas guys.  Much thanks!
All my board making tools are 900 miles away so i really don't want to reinvent that tool supply :)
Doug's board would be really really tight.  The board in there now is less than 3" wide and it's tight.
Good things to think on though.  It may just have to wait until I am back in the other shop.
