Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: jukelemon on August 08, 2026, 03:55:01 pm
Title: Removing tone stack from RRobs RR763
Post by: jukelemon on August 08, 2026, 03:55:01 pm
Hi all.
Looking for suggestions/guidance on how to remove the tone stack from the RR763 thus leaving one volume control only.
Would removing everything minus the .1 coupling cap do the job or do you think I would need additional changes?  I am thinking Champish volume circuit here.
Essentially, the end goal of a tube power amp with Volume control.
RR763 schem attached.
Thank you!
Title: Re: Removing tone stack from RRobs RR763
Post by: shooter on August 08, 2026, 04:17:09 pm
should do it
Post by: jukelemon on August 08, 2026, 07:30:47 pm
Cool and that is what I was thinking as well.
Thanks Shooter!
Post by: kagliostro on August 09, 2026, 11:39:28 am
Which is your purpose on doing that ?
Do you have faceplate space problem to resolve ?
Post by: shooter on August 09, 2026, 12:16:27 pm
V1a provides enough gain to drive the TS which sucks out gain, since there is no longer a gain sucker, pretty sure V1b will get over-driven beyond musical :icon_biggrin:
Post by: kagliostro on August 09, 2026, 03:34:44 pm
You can install a raw control or sub the TS with a James or simply a tilt control
Post by: jukelemon on August 09, 2026, 04:49:47 pm
Hey there.
I am building/tweaking an amp for my Leslie 900 conversion.  Right now it sits at the Proluxe design stage and I have the tone dimed because the EQ comes from the organ.
I am about to install a RR763 circuit in the Proluxe's place and I don't need a tone stack.
Post by: jukelemon on August 09, 2026, 04:51:49 pm
Meaning... removing the tone stack is not going to work here?
I could always use a 12ay or even set the bias points for a 12AU and like the original Leslie 122/147 amps?
Post by: sluckey on August 09, 2026, 05:05:56 pm
Or you could just turn the volume control down.
Post by: shooter on August 09, 2026, 05:12:02 pm
define "work"
i've typically found the 1st triode gives a good bump to S/N and signal amplitude, the TS typically erases the amplitude, which is made-up + sum in the 2nd triode
an AU would be my goto, it's all about what does this circuit need to produce to make the next circuit n user happy?
i've found though, what makes the engineer happy seldom makes the artist happy  :icon_biggrin:
Post by: jukelemon on August 09, 2026, 05:51:29 pm
Exactly
Post by: jukelemon on August 09, 2026, 05:54:22 pm
define "work"
Work = having a reasonable sweep on the Volume so that the amp doesn't go from clean to Metallica in 3 clicks lol.
I will try the circuit as is and just use an 12AY at first.
The amp is going to be driving a 75w, 15" WGS alnico and a 60w Jensen V21.
Post by: mountainhick on August 10, 2026, 08:10:18 am
If you want the amp to behave pretty much like it is with the tone stack, or if you find that iot has too much gain with stack removed, you can replace the stack with a coupling cap then a voltage divider.
Important: It is essential to place a coupling cap after the triode to keep high DC voltage off the volume pot.
Post by: RoadShow on August 10, 2026, 11:46:56 am
Why not just add a switch to the front or back to select between either the TS or cap?
Just for the flexibility...
Post by: sluckey on August 10, 2026, 12:28:38 pm
If this is truly your end goal, then you should completely eliminate the entire preamp section (V1A and V1B). Connect an input jack to a 250K volume pot and connect the pot wiper to the .001µF PI input cap. Like this...
Post by: jukelemon on August 10, 2026, 03:33:51 pm
Nice!!
That looks very much like a 122/147 power amp.  Thank you Sluckey!!
