Amp Stuff => EZ Board postings => Topic started by: Geezer on June 23, 2005, 05:15:33 am
Title: Should Pentode/Triode switch affect the   &nb
Post by: Geezer on June 23, 2005, 05:15:33 am
        > Should Pentode/Triode switch affect the bias... Found it!!
<< Prev Topic | Next Topic >>
Author  Comment
bluesbear
I only work on Fender's
(5/26/05 3:36 pm)
Reply  Should Pentode/Triode switch affect the bias... Found it!!
 Here's one I've never checked before; maybe they've all been this way.
If I bias the amp on pentode and switch to triode (using one ohm cathode resistors), the bias current jumps from 25ma to 60ma. If I bias it to 25ma on triode and switch to pentode, it drops to 3 or 4ma. Is this how it's supposed to work? If so, how do the tubes survive? If this is normal, which setting should I use to bias?
Thanks,
Dave
Edited by: bluesbear at: 5/27/05 5:59 pm
OldHouseScott
Hey get your own solder
(5/26/05 3:55 pm)
Reply  Re: Should the Pentode/Triode switch affect the bias?
 Are you using screen resistors and if so what value? Also if so, are you keeping them in circuit when switching to triode mode? Also, are you using a choke, or a resistor between the plate and screen taps on the PS?
With no or low valued screen resistors, and with no choke, I can imagine a vast difference in screen current between pentode and triode mode. This is a case where the self-regulating nature of cathode-biasing would help greatly.
OldHouseScott
bluesbear
(5/26/05 5:02 pm)
 Hi Scott,
That's why I'm confused. I'm using 1K 5w sandbox resistors and they are staying in the circuit when switched. I'm using a choke.
Dave
bluesbear
(5/27/05 6:14 pm)
Reply  Confusion is the problem
 I traced back from the screen resistors and took a closer look at the filter caps. I haven't a clue how I screwed it up so badly or why the amp worked as well as it did. This is a 5F6a in a Princeton chassis. I had already changed the can style cap to 40-20-20-20 so I thought I was ready to go... except that I had everything except what went to the first terminal wired to the wrong spot! I even had the choke wired across the 10k resistor... and IT was in the wrong place. I corrected it all and everything is fine. The bias jumps from -25 to -26 when switched now.
Scott, I don't know when or how I would have found this if I hadn't been double checking your thoughts. Your assistance has been vital!
Thanks!!!!!
Dave
 Topic Commands
jump to:  Tube Amp Building - Tweaks - Repairs (New)New Product Suggestions (New)Praises - Complaints - Suggestions (New)Buy - Sell- Trade (New)Archives (New)
Powered By ezboard® Ver. 7.32
