Amp Stuff => EZ Board postings => Topic started by: Geezer on June 23, 2005, 05:17:27 am
Title: champ filter caps         &nbs
Post by: Geezer on June 23, 2005, 05:17:27 am
        > champ filter caps
<< Prev Topic | Next Topic >>
Author  Comment
yellatele88
Senior tube assistant
(5/21/05 2:18 pm)
Reply  champ filter caps
 I have been looking around at some of the parts I have, and I wanted to build a 5f1type champ with my inventory.
I noticed that the 5f1 calls for a 16uf 450V and 2 8uf 450V caps. I have a whole bunch of 22uF 450V caps. Can I use them instead? I would imagine that I would just get better filtering with my caps.
Bob
wayneosdias
I will work on all amps
(5/21/05 3:20 pm)
Reply  yes
 Ya you can use them, I think the issue is if your gonna use the 5y3 recto, which will want a max of 20uf at the first node. Ive seen this asked before and the concensus was that the 5y will handle 22u fine. If you going ss you can filter it all you want.
wayne
phsyconoodler
(5/21/05 6:35 pm)
Reply  Re: yes
 Actually the first filter cap can be up to 33uf with a 5Y3 rectifier. 22uf will work fine. 33uf is the max for a 5Y3 and some people even use more and get away with it.
I built a Deluxe with a 30mf filter cap and it worked fine and is still working fine after a year.
yellatele88
(5/21/05 7:31 pm)
Reply  how do you find out
 Thanks for the info.
Just out of curiosity, how do you find out how big of a cap a rectifier can handle? The data sheets I have don't seem to list that spec.
wayneosdias
(5/22/05 2:04 am)
Reply  tdsl
 Here
tdsl.duncanamps.com/tubesearch.php
wayne
yellatele88
(5/22/05 8:28 am)
Reply  Re: tdsl
 Psycho,
Pleae pardon my ignorance, but is 33uF the max for the first filter in the stage, or is it the max for the entire filter section? I've used a 5y3 in an amp that had a total of 88uF in the filter stage, and it didn't seem to have any issues - I just didn't prefer the tone, so I went to a 5v4.
Bob
GroundhogKen
Moderator
(5/22/05 8:51 am)
Reply  Re: tdsl
 33uF is the maximum for the first smoothing cap that the 5Y3 sees. Any caps that are further down the power rail don't matter.
I ran 5y3s into a 47uF for quite a while without issue--no arcing, no tube failure. I ended up changing to 33uF to add a little sponginess.
Single ended amps like Champs are more prone to hum than push-pull, so increasing the filtering a bit over the vintage values is a good idea.
If you live in a region where the mains frequency is 50Hz, increasing the filtering of single ended amps becomes almost manditory--especially at the B+ node and the screen supply.
Ken
Rebel Leader
Junior tube assistant
(5/23/05 10:13 am)
Reply  Re: tdsl
 What is the factor that limits the amount of capacitance that
a tube rectifier can drive? Is it related to surge current at
startup when the 1st filter cap is discharged?
What is the failure mode if you use a large, say a 100uF cap,
filter capacitor for the first stage on a 5Y3 FW rectifier?
Cheers,
Rob
HotBluePlates
I only work on Fender's
(5/24/05 7:36 am)
Reply  Re: tdsl
 You got it, surge current when charging that first cap on startup.
The other caps don't matter, because they're separated by either a dropping resistor or a choke which limits the current surge to charge them.
punkykatt
(5/24/05 8:14 pm)
Reply  Re: tdsl
 I read somewhere that if you turn the power switch on for a few minutes, shut it back off , put the standby to play, and turn the power back on, it will have mercy on the rectifier. What do you think? Hogwash???? I think i was a Semour Duncan amp website.
 Topic Commands
jump to:  Tube Amp Building - Tweaks - Repairs (New)New Product Suggestions (New)Praises - Complaints - Suggestions (New)Buy - Sell- Trade (New)Archives (New)
Powered By ezboard® Ver. 7.32
