Amp Stuff => EZ Board postings => Topic started by: Geezer on June 17, 2005, 08:47:31 pm
Title: Screen glow when pushed
Post by: Geezer on June 17, 2005, 08:47:31 pm
        > Screen glow when pushed
<< Prev Topic | Next Topic >>
Author  Comment
whittele
I only work on tube amps
(2/6/04 11:28 pm)
 Good to back from sea. I finally washed the sub smell off and sleep in a real bed. Anyway...
I constructed a 50 watt plexi using only the bright channel (single volume only using half of V1 and a single "mixing" resistor) per the hoffman layout. Used Doug's tranny and mostly his parts. Here is the issue:
When I push the volume and I am not talking about pushing it hard say about 11 o'clock I get a red glow from inside of the plates. But NOT the plates. I am biased at 37.2 / 38mA at 461VDC (Sylvanias) and have the 5.6K grid resistors on the tube sockets.
This occurs with good Mullards, NOS sylvanias, JJ's, and EH EL34/6CA7.
The amp is otherwise very quiet and sound great.
What the heck is going on? Should I be concerned over amp health here? Thanks in advance. whittele
Dbltlk44
Junior tube assistant
(2/6/04 11:41 pm)
 Re: Screen glow when pushed
Can't help ya with the problem, but just wanted to say welcome back! Buddy of mine is a Sub driver, and always glad to see you guys make it back safe and sound..............
GroundhogKen
Forum Moderator
(2/7/04 9:22 am)
 Since you used the Hoffman layout, may I assume that you have 1K screen resistors on pin 4 of the power tubes?
It may be OK. I've heard that when the screen intercept rate is high ( tubes are being pushed hard ) the screens of cheap tubes will light up white. Red may be OK.
Install your least expensive set of tubes and wail on the thing for a while. If nothing melts, its probably fine. How's that for a scientific assessment?
Welcome back to dry land.
Ken
whittele
(2/9/04 7:33 pm)
 GHK,
I sure did use the 1K's. Nothing sounds out of sort and actually sounds pretty darn good. I just have not seen this before. And these are not cheap tubes - that is what bothers me. I will try to melt down the EH's. Fire up the lab....keep the extinguisher handy.
 Topic Commands
jump to:  Tube Amp Building - Tweaks - Repairs (New)New Product Suggestions (New)Praises - Complaints - Suggestions (New)Buy - Sell- Trade (New)Archives (New)
Powered By ezboard® Ver. 7.32
