Amp Stuff => AmpTools/Tech Tips => Topic started by: mark_enger on October 02, 2009, 07:32:15 pm
Is there a way to check the capabilitys of a diode by the numbers on them? I have a bunch and i need some for a ss recto id like to use what i have if i can some are labled in4003 any info would help mark
> labled in4003
1N4003 (that's a "one").
Google it.
same as 1n4007??? cool i got a bunch
> same as 1n4007???
No, 1N4003 is not the same-as 1N4007.
Mark,
current rating is the same in the 1N400x series (1A), peak inverse VOLTAGE rating is different. 1N4007 is 1000PIV, 1N4003 is less. (400PIV?, don't quote me as being spot-on without checking first.)
300v i beleave they upped to 600v or 1000v for just general uses i sure wish i had a way to identify these diodes mark
Why not quit guessing and do as PRR suggested? No one has mentioned the correct PIV rating for a 1N4003 yet.
Ok, I went and looked it up, everything I saw pointed to 200PIV. (LOL... I was in error, I'm glad I stated the "don't quote me as being spot-on without checking first.")
Just for those who are curious, after searching for "1n4003 specs" I found this:
http://www.nteinc.com/specs/original/1N4001_07.pdf
Specifies ratings for 1N4001 thru 1N4007. PIV (RMS & DC), Current (Surge & Average), etc.
