Other Stuff => Solid State => Topic started by: scole on November 27, 2009, 03:22:36 pm
what does the relay circuit do? can it be left out?
The relay switches the extra gain stage in and out.
Here is the hardwired, gainstage always on version:
http://www.el34world.com/projects/images/Stout.gif
(http://www.el34world.com/projects/images/Stout.gif)
Here is the switchable gainstage version:
http://www.el34world.com/projects/images/18WATT_VOLTAGES.gif
(http://www.el34world.com/projects/images/18WATT_VOLTAGES.gif)
Here are the schematics to compare if you prefer.
There wasn't a schematic for the no-switch version, so I edited out the relay circuitry.
can you make a master vol version of the stout?
why do we need the relay? cant we just put a direct switch? is it for safety? to keep high voltage away from the control panel?
more short are the wires less is the way to get noise
that can be a good reason
Kagliostro
The relay makes it very easy to switch remotely via a footswitch.
ok so you dont really need the relay, you can just put a regular switch in?
yes
does the stout with no switch have any clean or is it all gain?
