Other Stuff => Cabinets-Speakers => Topic started by: duke of earl on March 27, 2010, 09:17:26 pm
I just performed my first tolex job on a 4x10 speaker cabinet. I am looking for some corner trim that is not rounded. I don't want to file the corners to make the trim fit if ya know what I mean. Yall know where I might find some of these?
If you've got a router you can use a roundover bit on the cabinet edges - 1/2" or 3/4". sure makes things easy and then the metal corners fit too.
http://www.rockler.com/product.cfm?page=2127&filter=roundover%20bit%20router (http://www.rockler.com/product.cfm?page=2127&filter=roundover%20bit%20router)
If you hunt around you can find corners that can fit square boxes. They use em for PA cabs. I saw them one time when googling for speaker box and amp parts.
thanks tubesornothing. I have already tolexed the cabinet and don't want to mess it up.
The ones I am referring to go on **after** the tolex job. Rather than a radiused corner, they are a square corner, like you see on the PA cabs, and some amps like roland.
Do you know of any sources for the square corners?
I saw them while googling around. Cant recall the site, just search (and search and search) on google, you'll find them.
Check reliablehardware.com - some of the "Medium Road Case Corners" look pretty square (non-radiused) to my eyes.
Ahh you found it - thanks Boots.
Try renovator and restorer suppliers.
http://www.vandykes.com/product/cn1300012/corner-guards-for-trunks-chests-1-7-16-1
http://www.vandykes.com/product/cn1300014/corner-guards-for-trunks-chests-1-1-2-1
Van Dykes also has trunk handles, what a Tweed should have:
http://www.vandykes.com/product/203085/plain-trunk-handle
http://www.vandykes.com/product/203081/plain-black-trunk-handle-11-
http://www.vandykes.com/product/203087/medium-brown-trunk-handle-9-1-2-
http://www.vandykes.com/product/203167/nickel-trunk-handle-caps-2-1-4-
http://www.vandykes.com/product/205944/trunk-handle-end-holder
http://www.vandykes.com/product/203169/trunk-handle-loop-with-peg1
http://www.vandykes.com/product/203166/trunk-handle-caps-2-
http://www.vandykes.com/product/203085/plain-trunk-handle2
http://www.vandykes.com/product/203168/trunk-slip-loops
http://www.vandykes.com/product/210198/black-trunk-handle-11-
They also have woven cane, a traditional grille-stuff; and the groove-split used to put cane-weave on chairs nice and pretty (instead of bent-behind and stapled like most speaker grilles).
http://www.vandykes.com/product/cc1100015/1-2-fine-mesh-cane-webbing1
http://www.vandykes.com/product/cc1100017/3-4-mesh-cane-webbing1
http://www.vandykes.com/product/cc1100016/radio-net-cane-webbing1
Some very non-Tweed handles:
http://www.vandykes.com/product/cl180002/stainless-steel-arch-cabinet-pull2
http://www.vandykes.com/product/cl180002/stainless-steel-cabinet-pull1
Wow!!! Thanks PRR. That is exactly what I am looking for.
