Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: chip on April 10, 2010, 05:25:25 pm
This is my first try at a solid state rectifier amp. Just a few questions on the standby switch:
Push Pull, 2X6L6GC, 4X12AX7, Fixed Bias
1) Do I really need a standby switch for this amp?
2) If I do need a standby switch, is this location a good one?
3) If I put the standby switch in the location shown does it have to be rated for at least 500-700V?
4) Where can I find a switch that is rated for this high a voltage?
A whole article on standby and power switches:
http://www.freewebs.com/valvewizard1/standby.html
I prefer the switching before the diodes. Safer that way.
+ 1 for standby BEFORE diodes
I like to have a doubled switch
one for each branch of the transformer
Kagliostro
IMO switch before the rectifiers is overkill.
Fender put them after the rectifiers and the first PS filter stage with no problems.
If I leave out the standby switch, what are the risks?
I don't see any risks on a 2x6L6 amp. The STBY is more of a convenience (I like it) for a 40 watt amp.
Man its tradition, ya dont buck tradition. Just follow it, dont ask questions...
:wink:
Would a 3-watt 220K "bleeder resistor" somewhere between the power rail and ground help limit the initial voltage surge in an amp without a standby switch?
Don't know where I got that I idea. I've also seen those bleeder resistors located at the reservoir cap (1st after PT) and at the last (preamp) end of the power rail.
I see the two pairs of 220K resistors in series on both sides of the Standby switch in the OP's schematic (R26, 27, 28 & 29). Obviously those serve as "bleeder resistors" even though they are there for another purpose. BTW what is the wattage rating on those resistors going to be?
Chip
