Other Stuff => Effects => Topic started by: tubesornothing on April 11, 2010, 01:15:14 am
I came across a reverb driver circuit which uses 1/2 a 12AU7 and no transformer. 1k/25uF cathode. It feeds off the plate of the 12AU7 into 0.22uF coupling cap, then into a tank rated at 1.9k input. The other interesting thing is that the plate resistor on the 12AU7 is only 10k - I presume that is to help with driving the moderately low impedance tank? Upping the current?
The recovery is a little strange as well. 1/2 12ax7 with a 470k plate resistor. 3.3k/0.1uF cathode.
The reverb works quite well.
Sounds similar to some of Magnatone's circuits. Look at page 4 of this pdf...
http://home.comcast.net/~seluckey/magnatone/Magnatone_M10A.pdf
http://home.comcast.net/~seluckey/magnatone/Magnatone_M10A.pdf (http://home.comcast.net/~seluckey/magnatone/Magnatone_M10A.pdf)
Slucky,
I know this is a very old thread but do you have a new link to this Schematic by chance? looking into a 12DW7 cap coupled reverb as well. Thanks!
Click on the world icon below my name.
thank you
