Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: LooseChange on June 21, 2010, 06:37:12 am
Your basis tremolo circuit from the Fender AB763.
Changed the roach and the 3 caps and the tube. Everything appears to be in workinging order but the tremolo is weak. Have I missed something? Is there a way to make the tremolo stronger.
The tremolo does not come on very quickly either.
There is still something wrong.Those trems are as deep as can be when working properly.
Triple check against the schematic,taking note of voltages.Double check the bias supply as a feed wire goes to the top of the trem caps.
It it takes a moment to engage,you have a ground or cap charging problem.
There's an old thread in the Archives about tweaking the 6G16 bias-vary tremolo, but you may be able to apply some of the concepts to the roach-style tremolo:
http://www.el34world.com/Forum/index.php?topic=604.0
Is there a good way to test how well the roach is working? IRRC there was a thread here about that not too long ago but I'm not sure. Just because it's new doesn't mean it's good :wink:
Cheers,
Chip
Change the cathode cap. Also the cap out to the Depth pot.
I'll do that but there is no cap to the Depth control.
I read in Jack Darr's book that the large resistors have to be very close to spec and that drifting up will make a difference.
If the cathode cap doesn't do it, try another roach. Is this an old Fender amp? If so, you may have conductive fiber board issues.
