Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: JayB on June 24, 2010, 03:05:18 pm
It's a 2 channel hot rodded fender. Think AB763 trem/verb clean with out the trem/verb with a nice dirt channel that can do cleans to high gain lead tones. Series loop added. This one is going to a local blues player.
Forgot the back
Looks great! Any chance of some gut shots (or did I miss those somewhere)?
You didn't miss them. The wife took these. I should take some better ones before it goes to it's new home. I've been using a modified Hoffman approach to the layout. Works well for my needs. Still need to tidy up my rats nest over the power transformer.
2 more
Real professional looking; nice work. Gives us weekend solder jockeys something to continually aspire to. Thanks for sharing. Regards
dennis
lovely build, hope the new owner enjoys it
Beautifully done!
Wow looks great. How are you having the chassis artwork done? I've been looking for a place that will drill and silkscreen a chassis for a reasonable rate. I've been using Visio to design layouts but to date haven't found a place that will do the drilling or silk screening for small batches (unless you pay them well)
Thanks. I have all my chassis face plates done by BnP Lasers. http://bnplasers.com/index.html (http://bnplasers.com/index.html) She does an awesome job. I use Corel Draw for the face plates as that is some what of a standard and I just email the files to them. I'm thinking of learning silk screening myself for rack chassis work as I have run into the same problem as you. No one wants to do a one off 2 or 3 times a month and if they do, it's to pricey. I basically do everything myself except for the chassis it self. I just drill the holes and use a spare face plates as jigs that I had the nice lady, Jeanne, at bnp laser do up for me. That way I know all the pot holes and input jacks etc. will line up. I have made jigs from scrap baltic birch to do all my cut outs with for the cabinets. I use Visio for everything also including the chassis holes and cabinets. Makes planning ahead easy as cake.
I need to find something to cover the speaker cables with as the red/black 18 gauge zip cord is a bit boring to look at.
Jay - really nice looking build. :grin:
[hi-jack on]
FWIW BNP Lasers has done plates for 2 of my builds. I use Visio also and we had bad file compatibility problems. She worked through it and delivered really nice product but told me she wouldn't do it again - too labor intensive for her. If anyone knows of a way to get Visio files into Corel Draw format I'd be really grateful.
[hi-jack off]
Cheers,
Chip
[hi-jack on]
[hi-jack off]
Cheers,
Chip
Thanks Chip. You could save your drawing in Visio to a PDF. Then import that into Corel Draw but that takes some work too, she might be able to do it. I have done it successfully without to much work. The process really kind of chops everything up so you end up repositioning everything and removing any artifacts that may be there. I haven't seen any kind of converter yet.
