Amp Stuff => AmpTools/Tech Tips => Topic started by: PRR on June 27, 2010, 12:24:04 am
I had the need for a test oscillator when I was away from my signal generator, so I trotted out the Q&D oscillator, which had been broken by its storage.
So while tinkering, I did some things to it I'd intended to do for a while. I made it fake a repeated string pluck by adding an adjustment to make the oscillation decay to zero over a second or so, and a "plucker" to fire off repeated notes.
http://geofex.com/FX_images/Fake Guitar Oscillator.pdf (http://geofex.com/FX_images/Fake Guitar Oscillator.pdf)
You can flip it to a constant tone, too. I think this constitutes the world's most accurate, if boring, assistant guitarist.
One dual opamp and a few other parts.
http://www.diystompboxes.com/smfforum/index.php?topic=85408.0
Looks very useful.
Very cool concept. I think this would be great for fine tuning preamp stages. Use it like the "listening amp" in reverse. IOW injecting the signal at different points to see - and hear - what the effect of each specific stage is.
I wonder how difficult it would be to add a frequency adjustment. Not calibrated, just a way to go from say 80Hz to 1,000Hz.
Thanks,
Chip
How about running a signal generator through a normally-off momentary SW? Not automatic though.
