Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: RicharD on July 03, 2010, 11:21:30 am
Title: On the Bench: Gibson GA-1RT-1 What the......?
Post by: RicharD on July 03, 2010, 11:21:30 am
http://www.schematicheaven.com/gibsonamps/ga1rt.pdf
Really?  The reverb taps right off the speaker with alligator clips?  Yes this amp has been jacked with but the alligator clip thang loos original... maybe.  What keeps the reverb from feeding back?  Apparently nothing.  This thang squeals when turned up above 6 with the reverb engaged.  I guess that's how it is.  Cute amp on the outside, funky as all get out on the inside.  Looking for a reality check here.  This just doesn't seem right.
thanks!
-Richard
Title: Re: On the Bench: Gibson GA-1RT-1 What the......?
Post by: HotBluePlates on July 03, 2010, 12:37:35 pm
The method of attachment might be suspect, but using the speaker out as a reverb input has been done by others. It's a "foldback reverb" system. Ya could also call it a feedback reverb, as too much of it will result in feedback.
Think about it this way: You need to add reverb in your amp, but can't swing adding a tube. You need/want a low-impedance source of signal to drive the pan. The speaker output is already low-impedance, and more than enough signal available (guess 3w output, 4 or 8 ohm speaker, you get 0.6-0.8vRMS of low-impedance signal).
Now think like a Gibson designer and/or marketing dude... You have a circuit here which has 1 less tube than a VibroChamp (cheaper to retube, maybe), but has the VC's tremolo and it has reverb! You "kill Fender" on all fronts, and put an expensive effect in the lowliest student amp. Yeah, it feeds back if you turn it up too much, "... but it's got reverb!!"
You could make the 47k isolation resistor coming from the tank output more like 470k to see if it helps with the feedback at high volume/reverb settings, but it will obviously weaken the reverb at lower settings. You could add series resistance from the speaker terminal into one (or both) of the alligator clip leads.
I think it was Budda amps (maybe a different early-2000 boutique builder) who made a 5F6A Bassman-type amp with foldback reverb. The difference was they might have derived the reverb from the speaker output, but gave the reverb its own power stage and speaker. So you got dry and reverb, but coming from different speakers, and no feedback issue.
Post by: DummyLoad on July 03, 2010, 01:03:42 pm
try this - see what happens if you reverse the output polarity. just more curious to see (hear) what effect it has - it's likely not a "fix".
--ISO
Post by: HotBluePlates on July 03, 2010, 01:11:36 pm
Might be a bad plan, since with the footswitch in the off position, the speaker signal is tapped as an extra feedback signal to the grid of the input tube.
Post by: RicharD on July 03, 2010, 02:12:04 pm
I decided the alligator clip thang isn't original so I cleaned it up.  The footswitch wiring has also been changed.  I don't think polarity reversal is even an option where as everything is grounded to the tank body.  On a scale of 1 to 10, I give this amp a 2, only because it's cool looking.  I'll play with some series resistance to see if I can get better reverb stability.
Thanks guys for the reality check.
-Richard
