Amp Stuff => AmpTools/Tech Tips => Topic started by: angushung on August 09, 2010, 04:46:16 pm
Title: Looking for a reliable bias meter
Post by: angushung on August 09, 2010, 04:46:16 pm
Can anyone tell me a good bias meter that wont break my bank and can handle my 100 watt (4x EL-34b, 4x KT-88's,) heads?
Title: Re: Looking for a reliable bias meter
Post by: RicharD on August 09, 2010, 09:22:59 pm
right here
http://www.hoffmanamps.com/MyStore/perlshop.cgi?action=template&thispage=TubeSockets&ORDER_ID=375667907
scroll to bottom of the page
Post by: angushung on August 10, 2010, 05:35:06 am
Looks easy enough...and its in my price range. Would I need to build 2 in order to take on a 100 watt amp properly? Or would 1 tube at a time get me there?
Post by: tubesornothing on August 10, 2010, 06:32:03 pm
One will get you there.  Two will be faster.  Four will be really fast.  Super duper fast if you have four meters for each of them.
But, one is good enough.
Post by: DummyLoad on August 10, 2010, 07:43:05 pm
get and build 4 then build 4-to-1 switch box - that way you don't need 4 meters. it's royal PITA to check bias on one tube then let the amp cool down to check the next, etc... not very efficient.
--ISO
Post by: tubesornothing on August 10, 2010, 08:29:14 pm
Use silicone oven mitts...
Post by: DummyLoad on August 10, 2010, 09:25:48 pm
not wise to pull tubes hot... even w/ mits.   :lipsrsealed:
Post by: tubesornothing on August 11, 2010, 12:08:31 am
bah!
Post by: angushung on August 11, 2010, 05:23:18 am
I only have one decent meter. I guess I'll need to figure out what I'll need for a switch box.
Post by: malt on August 11, 2010, 07:07:56 pm
This may help you http://www.geofex.com/FX_images/biasprob.gif but I think you have to wire the resistor to pin 8
Post by: malt on August 11, 2010, 07:20:34 pm
I have some parts for a bias box but I still need some parts, got to order some from Doug.
well here is what i got so far
(http://i141.photobucket.com/albums/r63/malt_photo/solder027.jpg)
