Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: 67polara on August 29, 2010, 09:14:11 pm
Hello all. I was thinking that when I build the T.O. special that I would use KT77 and up the voltage to 475v into a 4.2 k load. What power out put might I expect and would it have any adverse effects on the existing circuit and or sound quality?
Tony
Hey Tony,
I don't know how I missed this post.
Check out the data sheet here. http://www.tubezone.net/pdf/kt77mov.pdf
It's interesting to see the note near the bottom of pg4 that mentions mounting distance of 3 1/2" minimum, I am unsure why.
I am not seeing anything in class AB1 fixed bias, but from looking at other charts we can guess between 60 and 70 watts.
The 4.2k impedance is a close enough match to the declare optimal 5.0k for P-P operation.
I would also consider tying pins 1 and 8 on your sockets so that other tubes might be installed
I could not imagine what tonal effects running KT77's would have. My only experience with these were in HI-FI equipment and even then they were ran ultra linear. (very loud VERY clean)
Ray
Thanks Ray.
I just noticed I can't find the exact spec's for my power transformer, that is current capabilities. The part number is 029032 a fender part. It is a bastard I guess.
This is what I know:
355v no center tap
6.3 volt no center tap
54 volt bias windings
No 5 volt windings
I need to know the power handling capabilities and the 6.3 volt current available. I need a little more than 4 amps 4.1 to be exact for the 6.3 windings. It came out of a fender super 60 red knob that had 2 x 5881's in it so I believe it is out of a 50 watt. The KT77 require 1.4 amps each instead of .9 for 6l6's. I think I will stay with cathode bias at first and see how that works out. I don't want to stress the output tranny to much, but I want lots of clean headroom.
Can anyone help me please?
Tony
Appears to be from a "Super 60"......that should give you an idea of the approx ratings/specs.
http://www.google.com/url?sa=t&source=web&cd=7&ved=0CDUQFjAG&url=http%3A%2F%2Fmusic-electronics-forum.com%2Fattachments%2F10360d1278030343-super-60.pdf&rct=j&q=029032%20PT%20fender&ei=TB-CTOauPNyBlgfXzdjPAw&usg=AFQjCNHXoR3-BZDaiRnJIVexRWs5r1CQHw
Thanks Geezer, but I already have that information what I need is the max filament current available for that transformer. Can't seem to locate that information.
Tony
That info is probably lost to the sands of time.........
The Super 60 required ~~3A filament current
The TOS w/ KT77's will need ~~4A
If you're concerned about the PT's safety, you could run the big tubes off the PT filament supply, & get a small 6.3V tranny to run the little tubes.....they are very inexpensive. I think I paid ~~ $7 for one.....yep, here's the link to a 3A unit (Doug also sells them)
http://www.mouser.com/ProductDetail/Xicon/41FD030/?qs=sGAEpiMZZMv4oUrzpPKU3NKK6KmzX%252bbMxt1WBAv2nNQ%3d
Great idea I never thought of that!!! That will fix everything :grin:
Thank you Thank you
Tony
Can you point me to a place to buy the filament transformer please. Seems like all I see they are really proud of and maybe I should just buy a new power transformer for a few bucks more. I have a small power transformer also maybe I will just use that one this amp is gonna weight a ton anyways so what could a couple pounds more hurt LOL.
If I have the current I will probably add reverb and trem to it LOL the chassis is the size of a small car anyways LOL it's from a Smarvo 300 watt bass amp. It had 6 KT88's on it but the iron was missing when I picked it up. I got the chassis and case for free though.
Tony
Never mind I didn't see the link you put on there for the tranny my bad.
