September 08, 2026, 11:35:44 am
Hoffman Amps Forum image Author Topic: How do you copy a sheet from one file to another  (Read 15649 times)
Offline LooseChange
    • Fix Your Darn Amps
« on: September 11, 2010, 01:13:33 pm »
I am trying to build a file with the layout, schematic, faceplate drawing into one book.  Right now they are all separate files. I can't seem to do it.  Any suggestions?
Thanks!
Call me Dan
www.fydamps.com
Re: How do you copy a sheet from one file to another
« Reply #1 on: September 11, 2010, 02:23:15 pm »
one the annoyances of Express SCH - it does not use the windows paste buffer. try grouping the object, save custom part and then placing into another sheet with the component manager - you loose the wires, but at least all the parts are there.
--ISO
« Reply #2 on: September 11, 2010, 03:24:55 pm »
Hey Dan,
Geezer knows how to put a layout and schematic into the same SCH "book".  Meaning he sends one attachment and it has two pages to it.  However, I don't know how he does it.  Maybe leave him a PM?
My guess is that it's a function of "file" in the upper left corner?
Also I don't know how many pages you can have with one?
Best regards, Jeff  Tubenit
Offline LooseChange
« Reply #3 on: September 11, 2010, 04:11:14 pm »
I need Geezers help! But he may be just designing both in the same book.
I've tried absolutely every possible way.
Call me Dan
www.fydamps.com
Offline Geezer
« Reply #4 on: September 11, 2010, 04:59:22 pm »
OK, I'll see if I can remember.....
1st, you can add more "sheets", or pages, using ExpSch.
Simply click on the "Sheet" tab @ the top of the page, then click "Add new sheet". The sheets are automatically named "Sheet 1", "Sheet2" & so on (the tabs for the sheets will be shown @ the bottom of the page), but you can rename them by clicking on the "Sheet" tab @ the top of the page, then click "rename this tab".
I'm guessing that you have multiple files that you want to copy & paste into a single "book" file with several different sheets for Schem, layout & such, correct?
In order to cut/copy & paste, "cuts/copies" & "pastes" must be performed in the same window....IOW, you cannot copy from  a ExpSch that is open in one window, then paste it into another ExpSch that is open in a different window. It must be done in the same window.
To do this, you must:
* 1st open the ExpSch file that you want to copy from, highlight & copy the section you want to be pasted into the new ExpSch file, then
* either create a new blank file, or if you already have a file you want to use as the "book" file, then open it by clicking on the "open file" icon @ the top of the page, then find the desired file & click on it to open it (thus closing the file you just copied from).
* now paste the copied information into the file you just opened (we'll call it the "book" file)
* now click on the "open file" icon again & find the next file you want to copy from (thus closing the "book" file)...it will ask if you want to save the file changes, click "yes". If it's a new file, be sure to save it somewhere that it can be easily found (a designated & properly named folder).
* once the next piece of info is copied, click on the "open file" icon again & re-open the "book" file & paste the newly copied info into it.
I'm thinking you already have the completed schems/drawings, so you just want to "organize" them. If so, simply create a new "sheet" in the "book file" & paste each full drawing into it's own sheet.
Continue opening files, copying desired info, pasting it onto new "book" file sheets, until you have all the info you want collected onto a single book file.
The key is to do all of this in a single window!
I hope this is understandable & helpful........ :undecided:
If not, just say so & I'll try again.
Geezer
attached is a book file I created quickily to show that it can be done.....I copied several different schems & layouts, & created individual sheets, then renamed them (see the tabs along the bottom of the page.)
NOTE: another important thing (if you don't already know it, which I suspect most folks do)....in order to copy large sections of drawings on .sch files, you cannot highlight/select, then right-click to copy. You must use the "control/C" function to do this.
IOW, highlight the section you wish to copy, then push the "C" button while holding down the "control" button. This will copy the section to the clipboard. If you try the "right-click & copy" method, it will de-select what you just highlighted & not work properly.
You can paste by either right-clicking & selecting "paste", or by pushing the "V" button while holding down the "control" button. Either of those methods will paste.
G
« Last Edit: September 11, 2010, 05:39:50 pm by Geezer »
Offline LooseChange
« Reply #5 on: September 11, 2010, 05:35:26 pm »
You are a genius!  That's probably the only thing I didn't try.
The trick is never to close the program.
Call me Dan
www.fydamps.com
Offline Geezer
« Reply #6 on: September 11, 2010, 05:38:40 pm »
Yes, you said in 8 words what I said in hundreds.....  :embarrassed:
 :smiley:
Offline LooseChange
« Reply #7 on: September 11, 2010, 05:42:37 pm »
You are still a genius!  :grin:
Thank you!
Call me Dan
www.fydamps.com
Offline Fresh_Start
  • noob de Lux
« Reply #8 on: September 27, 2010, 09:32:13 am »
Thank you!
No offense to your mutual admiration society, but I just figured this out yesterday by using the "HELP" function of ExpressSCH... :wink:
I was just trying to copy part of a schematic into a new file.  Select portion of schematic you want, don't worry about a few "extras", copy, open new file, paste... voila!  Oh, and then delete extras.
It would have been a helluva lot quicker if I'd just read this thread though!
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
