September 24, 2026, 08:22:31 am
Hoffman Amps Forum image Author Topic: 12AX7 heaters in series at 13.4V AC  (Read 7597 times)
Offline fluzo18
« on: September 13, 2010, 06:38:48 am »
Hello,
For a 12AX7, is it safe to run the heaters in series at 13.4V AC instead of 12.6V?
I'm building the tube pedal project at the library of information and I find the DC option with the 7812 regulator to be very noisy.
I've eliminated the 7812 and now I run the heaters at (ideally) 12V AC directly from the AC socket. I elevate the heater reference about 65V, using two 100 ohm resistors to a voltage divider from the HT circuit. The thing is I get 13.6V instead of 12V, and I presume it would fluctuate even more as the wall voltage changes.
It now sounds great and has no noise at all. But, is it safe?
Thank you.
Offline FYL
Re: 12AX7 heaters in series at 13.4V AC
« Reply #1 on: September 13, 2010, 07:51:31 am »
The spec is 12.6V ±10%, 13.4V under load is on the high side but OK. You may consider adding a dropping R.
OTOH, a properly used 7812 isn't noisy.
« Reply #2 on: September 13, 2010, 10:15:21 am »
I agree w/FYL, a 7812 should be utterly quiet. I am skeptical of dropping the heater volts off the HV supply, but if it works, OK, I guess. I haven't looked at the circuit, hence I don't have an idea of the ampacity of the overall power supply, but heaters use a solid order of magnitude more current than (the cathode > plate of) preamp type circuits...even running a 12AX7 at 12.6 volts. Maybe you could use two diodes connected head to tail and tail to head to drop .7 volts in your current configuration.
Offline fluzo18
« Reply #3 on: September 13, 2010, 10:48:46 am »
I'm not taking the heater volts off the HV supply, but elevating their reference to +60V to reduce hum. Normally, the artificial center tap formed by the two 100 ohm resistors go to ground. In my case, I connect them to a voltage divider coming from the HT supply (bottom image):
http://www.freewebs.com/valvewizard/heater.html
How would you connect the two diodes to lower .7V? Do you have a schematic?
Thank you.
« Reply #4 on: September 13, 2010, 10:56:25 am »
here the schematic
http://www.freewebs.com/valvewizard/heater.html  :laugh: (sometime that happen also to me ...)
Kagliostro
Offline stingray_65
« Reply #5 on: September 13, 2010, 11:07:26 am »
Funny This should come up about the7812 chip as a friend and I were discussing that series recently.
I have been using that family of regulators for 20+years now and have always found it to be EXTREMELY quiet.
I would look much closer to what is going on before modding things heavily.
Just my .02 take it or leave it.
Ray
Offline stingray_65
« Reply #6 on: September 13, 2010, 11:11:42 am »
do you have a photo of your project?
Ray
