September 13, 2026, 09:50:54 am
Hoffman Amps Forum image Author Topic: Glo Champ  (Read 42799 times)
Re: Glo Champ
« Reply #50 on: December 19, 2010, 07:56:04 pm »
> -37.75V Vgk so we need ~~53VRMS
26.7 V RMS.
Re: Glo Champ
« Reply #51 on: December 19, 2010, 08:01:19 pm »
26.7 V RMS.
oh yeah, duh! it's SE...   :rolleyes:
that stage ought to be doing at least that... at least sim says it is...  :-\
« Last Edit: December 19, 2010, 10:55:30 pm by ISOTone »
Re: Glo Champ
« Reply #52 on: December 23, 2010, 11:42:56 pm »
1958 Radio Shack industrial catalog:
Re: Glo Champ
« Reply #53 on: December 24, 2010, 12:44:13 am »
VERY UNSAFE homemade plate cap - don't try this at home... i'm a professional idiot.  :lipsrsealed:
Re: Glo Champ
« Reply #54 on: December 24, 2010, 02:26:31 am »
Hi ISOTone DummyLoad
Can I suggest, as a temporary solution, to use a motorcycle spark pipe ?  :wink:
Kagliostro
 :grin: :grin: :grin: Merry Xmas  :grin: :grin: :grin:
« Last Edit: July 16, 2016, 01:03:00 am by kagliostro »
Re: Glo Champ
« Reply #55 on: December 24, 2010, 09:54:23 am »
thanks kagliostro, i'll see if i can find something that fits after the holidays.
happy holidays to too!  :grin:
Re: Glo Champ
« Reply #56 on: January 15, 2011, 10:27:14 pm »
Re: Glo Champ
« Reply #57 on: January 16, 2011, 01:25:31 am »
sorry, it's been on the back burner. i need to get some sound clips posted and you don't want to hear my playing - not even if yer three sheets to the wind. i'll see if i can arrange for a friend to come by and record some sound bits.
PRR, you requested some additional telemetry - g2 currents, etc.. it's late - i'll grab it tomorrow after i get back from work.
respectfully,
--ISOTone
Re: Glo Champ
« Reply #58 on: January 23, 2011, 11:42:49 am »
PRR, here it is... i replaced the G2 resistor w/ a 500Ω - down from 1KΩ.
at idle, vR500Ω is 4.2V - under heavy loading (hard picking/strumming and dimed) i see 11-11.5V with an occasional pk. to 12V. this is measured with a fluke 87.
so, at idle - we have 8.4mA @ ~~500V g2 - roughly 4.2W - full power 11.5V, @ 23mA or 11.5W - i think we are still safe here; thoughts?
the dynamics have improved remarkably and seemingly so has the output power, amp seems to have a lot more bite now. i'm using a godin LG w/ hot humbuckers.
i'll slap a 1KHz tone and dummy load on it to get some power output telemetry later on this afternoon and update unless you direct otherwise.
i really love this amp - i'm going to experiment with another peanut tube for a smattering more nastiness; you may or may not approve - it's the 5840W. i'll post up some bias conditions of what i think will work
are we insane?
:angel
--ISO
Re: Glo Champ
« Reply #59 on: January 23, 2011, 11:12:07 pm »
So you have 500V(?) supply, G2 was 492V-476V, is now 496V-488V.
Hard to understand any "wow!" change from 2.5% increase.
Is it possible to have Buttery switch resistors behind your back and see if you consistently know the difference? (If that's just too much trouble and danger, I understand.)
> are we insane?
Hmmmph. Not like some snowplow truck owners. I just saw a sig boasting a 5 inch exhaust system. I re-piped my truck with 2.25" and now I feel teeny. Which is stupid, because this truck has as many pistons and as much horsepower as BOTH the cars in the drive put together, and AFAICT I can't use more than 1/5th of that at 5MPH on slick surface.
Re: Glo Champ
« Reply #60 on: January 23, 2011, 11:56:42 pm »
true. maybe it's because it has been a while since i/we fiddled with it?
should not be too much trouble... however, buttery has been pretty busy lately and scarce around these parts. hopefully he'll chime in and get a break long enough to spend a small bit of time on it with me.
honestly, i've been spending more time with the burger king amp i posted just after x-mas. it's a lot more sane of a project to work on by myself. then it's on to a 4 x 6V6 princeton reverb for a friend - i'm trying to sell him on a single channel vibroverb instead. the glo champ has to be a slow and methodical and well thought out project - it's just too damn dangerous to cut corners on and slip-shod together.
5 inch exhaust system...
sounds about as useful as those 26" wheels and rubber bands for tires guys are putting on their cars these days.. :rolleyes:  BTW, did you ever get the idle kinks worked out?
Re: Glo Champ
« Reply #61 on: January 24, 2011, 12:27:41 am »
i have worked on some of the mechanics some. all comments and/or suggestions welcomed. the tube is housed in a perforated aluminum cage. i'll try to get an elevation view done in the next day or two.
--ISO
Re: Glo Champ
« Reply #62 on: December 13, 2018, 08:04:58 pm »
I have found the mother-lode of H-K tube data.
http://www.tubecollectors.org/h&k/h&k.html
The HK1554 has a suggested condition for Audio, Class A, Single Tube at 350 Watts output. 4,000+W push-pull B with a mere 150W grid drive. 250W filament will keep you warm tonight. (2 deg F last night.) The 3054 will do more, but at 30" tall is not going to fit in a Combo.
Re: Glo Champ
« Reply #63 on: December 15, 2018, 06:03:24 am »
thanks for sharing that link. impressive tubes.  :icon_biggrin:
i actually kicked around the idea of P-P AB1 with a pair of HK257B (4E27A/5-125B) for a 150W+/- amp, but i think trying to buck hum with directly heated cathodes is more a hassle than it's worth, also, designing a clean +/-20A DC heater supply that can take power-on surge of those heaters with a respectable life span isn't trivial, so, meh! i do have all that iron laying around, + i should at least use it, no? that's what i was doing fooling around with those KT120 SE with 750V B+. thinking a winter studio amp might be something to tackle in the future.
getting down to 20's or teens here basically shuts down the city - stay warm! hope all is well otherwise. oh yeah, shouldn't you be finishing up your tube amp book? ;-)
30" bottles? depends on your definition of combo! CMI as shown in the attached pic. might work. pass the soldering iron and send in the roadies.
Re: Glo Champ
« Reply #64 on: December 23, 2018, 12:55:39 pm »
1947's TV transmitters used flocks of 4E27(HK257).
Re: Glo Champ
« Reply #65 on: December 23, 2018, 02:24:19 pm »
i see another tube in that lineup i've been wanting to experiment with: the 6AG7 used as a transformer loaded reverb tank driver or headphone amp.
Re: Glo Champ
« Reply #66 on: January 06, 2019, 12:09:11 am »
Like Crosby, Stills, and Nash, and Young.... Heinz, Lewis, and Kaufman did several sorts of business under several names at several places.
Here is an L&K Los Gatos ad touting the 254.
Re: Glo Champ
« Reply #67 on: March 04, 2022, 08:44:53 pm »
Before that: Lewis' name on the brand and a 125W Pdiss claim.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: Glo Champ
« Reply #68 on: March 05, 2022, 02:44:44 pm »
WOW !! Another really nice thread !!
https://soundcloud.com/ukiuki
Re: Glo Champ
« Reply #69 on: August 05, 2022, 02:31:38 pm »
Ya shudda bought them in 1948.
Re: Glo Champ
« Reply #70 on: August 05, 2022, 04:59:43 pm »
guessing '48 was a good year for bargain hunters across the globe  :laugh:
the OEMS sold us, well priced us $8,000 for the pair, we got them from an Eimac rep for $4000
lasted about 18khs before they started diftin or sparkin
3CX800A7
YC156A
Re: Glo Champ
« Reply #71 on: August 06, 2022, 12:28:26 am »
Replaced by:
Re: Glo Champ
« Reply #72 on: August 09, 2022, 06:34:37 am »
Replaced by:
I have a couple of those.
Planning to re-visit this project around the end of summer, only with octal tubes for the preamp - Lineup something like this: 6J7 > 6SF5 > TS > 6SF5 or 6J5 > 4E27A.
--Pete
Re: Glo Champ
« Reply #73 on: August 13, 2022, 12:35:25 pm »
Replaced by:
--Pete
Probably not the "longest" thread but holy cow Pete I would nominate for the longest amp time project? Just kidding kinda but I've had several amps that I "thought" was finished only to opened up years later to modify or perform various other mods or improvements. Hope you get it glowing as you wish loudly and proudly once again - which I know you will.
Re: Glo Champ
« Reply #74 on: September 03, 2022, 03:26:40 pm »
...using a HK257B/JAN-4E27....
Or for different flavor: https://www.ebay.com/itm/175325794001
GK-71 ( 4E27 ) Vintage generator pentode tube Original Package NEW NOS
Russian improved work-alike for HK257.
There's apparently many places to buy these.
Check entire datasheet for differences.
https://frank.pocnet.net/sheets/018/g/GK71.pdf
(heater way different?)
Re: Glo Champ
« Reply #75 on: September 03, 2022, 04:20:19 pm »
Nyet comrade!
Interesting looking tube; is much larger than the 4E27 - At least it seems as such. Looks like the plate material is graphite?
--Pete
Re: Glo Champ
« Reply #76 on: September 04, 2022, 09:36:16 am »
An hungarian friend that sometime arrive here in Italy  to the radio amateur Flea Market in Pordenone and Marzaglia, some time ago had a large stock of those tubes, unfortunately this Is of any help for you ☹️
(Also he often has GU81 tubes)
No chances for the 813 or 811 ?
EDIT
Don't know about expedition cost
https://www.ebay.com/itm/175325794001?_trkparms=amclksrc%3DITM%26aid%3D1110011%26algo%3DHOMESPLICE.DISCLISTINGS%26ao%3D1%26asc%3D20191002092920%26meid%3D4c46ce5a01464540a54feeee5503f570%26pid%3D101096%26rk%3D6%26rkt%3D12%26sd%3D304614261394%26itm%3D175325794001%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3Ddefault%26brand%3DSoviet&_trksid=p2332490.c101096.m3021&amdata=cksum%3A1753257940014c46ce5a01464540a54feeee5503f570%7Cenc%3AAQAHAAAA4OF5%252BpTTB9eWzF1iVTnQDCtZCCH3fRXts9K%252BhqfJSnqTbPXeAWObzUMuLaXlvjluaHjMzX4v0J%252BqyoFbajHJTzndBS0GrKNqz6gS438ukFOrQBCmnH6JmdcwYVYZavYhUajYGiw4wbSsIR%252BSUnYKI%252Fnh9vDO8YYBCtDW4MoZ6jB3A9CHoZK%252Bq6EpH8yeHvWeyKOxNk%252BqUmloLnrU%252BmOerXcZUp5NAJf4WT7HOt%252F%252BlSHuHpbWsFSC9FBflS9hY427u0nqpUYp5qg0eTTaLDJLsft53q%252B2TMIAEMssq6Lz7MzU%7Campid%3APL_CLK%7Cclp%3A2332490
https://www.ebay.com/itm/284906185255?hash=item4255bb6227:g:Sq4AAOSw3tpi2qYk&amdata=enc%3AAQAHAAAA4A0dkBoRCSnk2ojgVADC57IGhFzYuK2F71FFkUujcCiDHEdR13nbNmX92vGfRGxuJ%2BYdj7KFx7AmzGjEFVMc5bUWuJq4STwBE8bnegVbqmIGT0f2yljYHemw0ZBr54qtN%2B3uOyhQYW2f0T2a%2BuKFoQPZeSe3MD5bYXJOUDs4cH5J0yRRosHmiENXJcjIXPWzOG2yO3KrCf0yKDC2OSmxj8lcKc8n6NGxSczygR8Fu2fKUDzOmtFTZG998rHQa1NJhHuML9CCEZ32MkM1yIfGnhTJIhahWY7Cg%2Fijeyv%2BIc7W%7Ctkp%3ABk9SR9jfkZDhYA
Pete Millet build an SE with 813 as Power tube, but il was used in triode mode
http://www.pmillett.com/813_se_triode_amps.htm
« Last Edit: June 01, 2025, 04:57:45 pm by kagliostro »
