September 11, 2026, 04:01:31 pm
Hoffman Amps Forum image Author Topic: Interesting low power amp  (Read 9334 times)
« on: October 21, 2010, 12:00:56 pm »
Saw this on ebay and it is interesting.
low power tube amp
I'm curious to find out what the power transformer is and the output transformer. I wonder what level of rectified DC he is getting from that pt?
« Last Edit: October 21, 2010, 04:01:56 pm by mresistor »
Offline FYL
Re: Interesting low power amp
« Reply #1 on: October 21, 2010, 01:09:29 pm »
Or how to recycle old AT power supplies...
« Reply #2 on: October 21, 2010, 01:12:38 pm »
Right, isn't that cool...   I looked at jameco website and couldn't find any power trans that gets the kind of secondary voltage needed to power the tubes... what't the least amount of plate voltage needed for a 6AQ5 to operate?
Do you think he's using something like this for the PT
« Last Edit: October 21, 2010, 01:40:53 pm by mresistor »
Offline moonbird
« Reply #3 on: October 21, 2010, 01:38:33 pm »
Seen this one before -- on one of his sales he posted a schematic of this "model" or something close. Will try to find it if you are interested.
How can I post stuff on this forum are there size limits?? thx
« Reply #4 on: October 21, 2010, 01:41:39 pm »
he's got the schematic posted in the auction.... what I want to know is what is he using for pt and ot?
Offline FYL
« Reply #5 on: October 21, 2010, 02:23:18 pm »
PT: ex-surplus Jameco 102692
OT: looks like a low voltage Tamura 130B used as a SE OT. Could very well be a PL5.0 5VA model
http://www.tamuracorp.com/clientuploads/pdfs/engineeringdocs/PL5.0-XX-130B.pdf
Full schemo attached.
« Reply #6 on: October 21, 2010, 02:41:28 pm »
Kind of an odd setup with the power & heater transformers in series and the dropping components and ckt arrangement affiliated with the heaters on the secondary side. Otherwise, pretty conventional. Which isn't in any way a bad thing.
« Reply #7 on: October 21, 2010, 03:28:22 pm »
I've seen him normally use these torroidal trannies in the link. He uses the other 120 tap for B+ and parallels the two 6V taps. He's also used the 7v trannies and that may be from voltage drop to give maybe 6.5v for the heaters? There's also a lower powered one but it's only $1 less. At $11 ea that's a pretty good price and the company will ship out up to 8 or so w/out raising the price for shipping. The guy is retired I think & seems very nice and answers questions if you ask him, but mine weren't too specific in trying to get building or design info from him. You could always try? I'd be curious what info he'd be willing to give out.
http://www.antekinc.com/details.php?p=18
« Reply #8 on: October 21, 2010, 03:44:18 pm »
So he's using around 115v for B+?   Interesting. I wonder how much total current the two tubes are pulling. Help me out here, how is he getting the hv secondary winding? Inputing on one of the primarys and then using the other primary as a secondary?
  I did ask him if he would identify the two transformers. Wonder if he'll answer with part numbers. Seems like a cool project, and great little amp for noodling softly in the casa.
This pt is only $20. But I guess if this one were used the amp would be a little more than a half watt out...     :smiley:
« Last Edit: October 21, 2010, 03:48:50 pm by mresistor »
« Reply #9 on: October 21, 2010, 11:06:18 pm »
Here's how he's hooking up the tranny and it's got the part number on it too. This is a small triple pentode self splitter he made a while back.
Offline gh1
« Reply #10 on: October 22, 2010, 08:45:54 am »
Still waiting for my Toroids For Dummies book to arrive. Can anyone explain in simple terms how this is wired? Sorry if this is the wrong area for this post.
« Reply #11 on: October 22, 2010, 09:20:01 am »
For gh1
Why don't start a new tread for this new question  :wink:
It seems to me that the connection shown on your picture is confusing
Connection A / B /C / D for me mean connection to one of the primary of the transformer that is in the first (upper) part of the image you post
Connections E / F connection to the second primary winding that is used as a secondary winding
connections blue and green are simply parallel connections of the 7v windings
As I can understand you want to obtain both the B+ and the filament voltage from that transformer
so connect
red 1 and black 1 to the line voltage
red 2 and black 2 to the diodes bridge
blue 1 to blue 2
green 1 to green 2
Connecting blue 1 to blue 2 and green 1 to green 2 you must control if you have the right output voltage (7v) there are BIG problems if you connect the two windings antiphase
Connected this way you have the B+ and filament voltage available
Hope I've understand your question
Kagliostro
Offline FYL
« Reply #12 on: October 22, 2010, 09:20:34 am »
The PT uses a dual 115V primary winding, one is connected to the mains, the other is used for B+.
Any common transformer will also work as an auto-transformer: 10V thru 10 turns on the primary will reflect as 10V (minus losses) on another primary 10-turns winding. Quite effective but dangerous as there's no galvanic isolation.
« Last Edit: October 22, 2010, 09:23:43 am by FYL »
Offline gh1
« Reply #13 on: October 22, 2010, 09:37:13 am »
Thanks :smiley:
« Reply #14 on: October 22, 2010, 01:44:07 pm »
what I do is host my pics at photobucket and then link to pics directly, you could use any pic hoting service that way.
« Reply #15 on: October 22, 2010, 02:05:00 pm »
or simply re-size the picture or file with a photo/camera program
