August 29, 2026, 08:54:27 am
Hoffman Amps Forum image Author Topic: Choke Value for an 18 Watt Stout  (Read 5482 times)
Offline knotscott
« on: November 08, 2010, 07:18:58 am »
How critical is the exact value of the 4H choke in the 18 Watt Stout power supply?  I've got an 3H choke that's available and free, so I'd hate to spend more money if the one I've got will work well enough.
TIA.
Offline FYL
Re: Choke Value for an 18 Watt Stout
« Reply #1 on: November 08, 2010, 08:02:19 am »
There's an empirical formula for a CLC supply (C1 + C2) * L > 200, with C in µF and L in H.
The stout use 40 and 20µF for C1 and C2, sum and product is 180 with a 3 H choke, below the recommended 200 but good enough as it's only a 10 % diff and because the formula applies to a global supply (plates + screens + small signal) - you only feed screens + small signal in a Stout.
Offline Fresh_Start
  • noob de Lux
« Reply #2 on: November 08, 2010, 08:41:06 am »
Just make sure that the current rating of your choke is adequate for two EL-84 screen grids and your preamp.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
Offline knotscott
« Reply #3 on: November 08, 2010, 09:17:40 am »
Thanks to both of you for the replies.  The choke actually came out of an amp chassis that had two EL84 output tubes, so I'm assuming its fine.  What will I ever do with the $20 I saved?  :wink:
