August 29, 2026, 08:53:19 am
Hoffman Amps Forum image Author Topic: Princeton Reverb with a Twist.  (Read 7397 times)
« on: December 04, 2010, 01:16:25 pm »
Nothing to write home about, but it's quiet, the reverb absolutely melts yer ears and the tremelo is very lush sounding. this one took me a while. i was managed to to make only one wiring error on this one in the tone stack ckt (wired 250pf to bass pot, not treble pot, doh!) she's found a new home at local studio, but problem is... i don't want her to go.  :sad:  wiring is my typical hap-hazard mess, but it works well.
gear pr0n.
Re: Princeton Reverb with a Twist.
« Reply #1 on: December 04, 2010, 01:37:09 pm »
Looks good to me! (Which may be a negative!)
No shortage of chassis real estate. What influenced your 9-pin tube layout?
« Reply #2 on: December 04, 2010, 01:50:37 pm »
thank you! and yes, no real-estate shortage. the chassis line goes from really cramped 10x17 to 16x17 - it's going in a studio, and they're not too worries about the size. all that room made the wiring that much easier.
signal flow... it's the fender plan - only right to left + the reverb tank had to fit on the top chassis and far enough away from AC ckts.
lastly, the white mallory 150's strategically placed in the ckt. sound better...  :rolleyes:
 :wink:
Offline RicharD
    • Toxic Water
« Reply #3 on: December 04, 2010, 03:18:38 pm »
I just took it for a test drive.  It's delicious.
Offline Fresh_Start
  • noob de Lux
« Reply #4 on: December 04, 2010, 04:30:22 pm »
Thanks for sharing those gut shots.  Looks really nice!
Excellent!  Any tweaks to the standard circuit?  What transformers?  Are those Penta preamp tubes & if so which ones?
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
Offline RicharD
    • Toxic Water
« Reply #5 on: December 04, 2010, 06:23:14 pm »
Iso only uses NOS tubes.  Probably GE.  As I recall, he changed the 3M3 to a 2M2, added a dwell pot (small tank), and added grid stoppers.  He'd be the better / more accurate person to describe the circuitry.  I was only the cheerleader on this one.  I didn't twist a single screw although I did help with the milling of the chassis.  The amp is very rich in the classic "Fender" sound.  With the volume cranked and the tremelo on, there's a schweet fade when the AC signal exceeds the DC tremelo pulse.  Probably not the most apt description, but it's really fun to play, especially for the right hand.
« Reply #6 on: December 04, 2010, 11:22:16 pm »
thank you!  :-)
some tweaks -  47nF PI to 6V6 G1 coupling caps. 2.2M bridge resistor instead of 3.3M, 1K5 grid stoppers on 6V6, silver mica instead of ceramic disc caps, short tank & dwell pot. 50uF 1st & 2nd PS filter stage caps. trannies are magnetic components. it does sounds very nice. :-) if i were a decent player there would be sound clips...
the tubes are all NOS; sylvania for all pre-amp tubes, RCA smokey glass 6V6GT, and Tung Sol (not tungsolski) 5U4GB. the sylvania 12AT7 reverb driver is a black plate variation.
thanks,
--ISO
Offline phsyconoodler
« Reply #7 on: December 06, 2010, 02:22:03 pm »
Think that chassis is large enough?Looks very nice though.
« Reply #8 on: December 06, 2010, 03:10:43 pm »
that series chassis (par-metals 14 series) jumps from 10" deep to 16" and 10" is too cramped with a reverb tank w/o funky L-brackets and whatnot to mount it to. so yes, it's large enough...  it is designed to be used exclusively in a rack; 16" depth should not be a problem for most rack cabinets.
the big picture is that chassis easily integrates into single channel super reverb, JTM45, twin, or any 2 or 4 power tube setup with reverb and tremelo with only minor machining mods for PT, OT, and additional pair of output tube sockets, if needed.
:wink:
