August 29, 2026, 08:50:57 am
Hoffman Amps Forum image Author Topic: Favourite master for cathodyne PI's  (Read 14016 times)
Offline phsyconoodler
« on: December 14, 2010, 10:25:01 am »
What are the feelings about master volumes for the cathodyne PI?
  I'm putting one on my latest build but wanted to get some opinions on people's favourite ones.It's basically a Princeton Reverb with a couple of tweaks.
  Cheers.
Offline chocopower
Re: Favourite master for cathodyne PI's
« Reply #1 on: December 14, 2010, 11:04:34 am »
Hi!
I was thinking about the same.
Right now i´m using the Matchles way in my Green Bullet.
schem:
http://picasaweb.google.com/davidageitosfuentes/GreenBullet?authkey=Gv1sRgCN6Bwp3Ql576Lw#5531371600280562306
topic:
http://www.el34world.com/Forum/index.php?topic=8349.msg94519#msg94519
I don´t like it. Too thiny sound.
Maybe if i wire it before the two PI output caps (.022) and feed the pot with .220 pair it get a better sound...
just me and my imsonia.....
David
Offline Fresh_Start
  • noob de Lux
« Reply #2 on: December 14, 2010, 01:54:14 pm »
I tried a cross-line PPIMV in a Princeton Reverb circuit too and didn't like it.  By the time it made a noticeable difference in volume, the tone lost something.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #3 on: December 14, 2010, 02:40:02 pm »
This just came up a few days ago...
« Reply #4 on: December 14, 2010, 04:42:05 pm »
It looks like you replace the 1meg with the 500k pot,change the 1k to 1.5k and splice the connection,then run the wiper to the grid.Correct?
« Reply #5 on: December 14, 2010, 05:09:31 pm »
Yep. Except, don't bother changing the 1K to 1.5K. This drawing was specific to a 5E3.
« Reply #6 on: December 14, 2010, 05:12:52 pm »
Thanks Sluckey.That one works pretty good?
Offline LooseChange
    • Fix Your Darn Amps
« Reply #7 on: December 14, 2010, 05:17:18 pm »
I don't know about that one... DC on the pot... Gonna make some noise!
Call me Dan
www.fydamps.com
« Reply #8 on: December 14, 2010, 05:24:37 pm »
DC on a pot is only an issue IF  it causes current to flow thru the pot.
« Reply #9 on: December 14, 2010, 05:35:22 pm »
What about this one;
Offline darryl
    • ValveTone Amplification
« Reply #10 on: December 14, 2010, 05:40:35 pm »
This is an amplifier I described here a few months ago. It has the master volume arrangement I use in most of my designs.
« Reply #11 on: December 14, 2010, 05:45:34 pm »
Interesting.What are the 27v zeners for?
« Reply #12 on: December 14, 2010, 05:48:17 pm »
YIKES!    :huh:
« Reply #13 on: December 14, 2010, 06:06:58 pm »
Ha Ha Ha! I suck at drawings.
Offline darryl
« Reply #14 on: December 14, 2010, 06:14:33 pm »
The 27 volt zeners have two purposes:
1. The zener voltage is set so with the master volume at max, the PI and output stages can be overdriven, but not to the point where the cathodyne is generating really harsh distortion.
2. As the master volume is turned down, the power output of the amplifier is steadily reduced by the symmetric clipping effect of the zeners. This clipping is easily achieved, without the additional gain stage which would otherwise be necessary to generate distortion, by overdriving the stage before the master volume.
The distortion generated by the zener clipper is not as smooth as genuine output stage overload, but still sounds acceptable ( to my old ears  :icon_smile: ).
Offline topbrent
  • In pursuit of more cowbell...
« Reply #15 on: December 14, 2010, 08:03:15 pm »
The ÷13 (Divided by 13) CJ-11 uses a Ken Fischer type II. Known these days as the LarMar type MV.
On this drawing, conger calls it a cross-line, but I believe he is incorrect in his terminology.
Very Cool little amp regardless.
« Last Edit: December 15, 2010, 01:44:45 pm by topbrent »
Offline Fresh_Start
  • noob de Lux
« Reply #16 on: December 15, 2010, 06:36:04 am »
The one chocopower linked to in the 2nd post is a crossline.  IIRC Ken Fisher called this one "type 2".
Cheers,
Chip
Quote from: PRR
Offline Shrapnel
« Reply #17 on: December 16, 2010, 03:16:30 am »
Not really any different than the usual gain or volume pot that acts as a grid resistor as well. Only real difference is the "ground" potential is elevated to a more normal working bias voltage position.
-Later!
