August 29, 2026, 08:53:42 am
Hoffman Amps Forum image Author Topic: Can ripple be checked with a multimeter?  (Read 5567 times)
Offline frank57
« on: December 25, 2010, 11:38:04 am »
Is it possible to see how much ripple is on a filter cap using a multimeter?
I can't remember where I saw it but someone mentioned switching to ac volts on the multimeter but didn't get
more specific.
Re: Can ripple be checked with a multimeter?
« Reply #1 on: December 25, 2010, 11:41:21 am »
You could try it I guess.
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #2 on: December 25, 2010, 02:19:16 pm »
I get some sort of reading on the AC scale. But I would rather use a scope so I can see peak-to-peak, and frequency (half vs full wave) to check if a diode is out, or if the rectifier is way unbalanced.
Offline Fresh_Start
  • noob de Lux
« Reply #3 on: December 26, 2010, 09:20:46 am »
My DMM has a max/min and an average function.  Yes, you switch it to measure AC volts.  So you can measure ripple with a DMM... sort of.  A scope or analog meter is much better though.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
Offline frank57
« Reply #5 on: December 27, 2010, 04:47:36 pm »
