August 29, 2026, 08:52:57 am
Hoffman Amps Forum image Author Topic: I draw a layout for Butterylicious Mic Pre - Can I have councils and help ?  (Read 5292 times)
I've tried to draw a layout of the Butterylicious Octal Mic Pre with 6SL7 & 6SN7
the original thread is this
http://www.el34world.com/Forum/index.php?topic=10116.msg94794#msg94794
Sorry for the neavity of my draw
I need your help to complete the draw, need your councils and revise
My transformers are different from those used in the original project
I've:
an input transformer with a CT in the primary winding (not present in the original)
this one
http://it.rs-online.com/web/search/searchBrowseAction.html?method=browseSubRange&Ne=4294583802&N=4294571284&productNum=2106352
an output transformer with two secondaries, one with CT (not present in the original)
this one
http://docs-europe.origin.electrocomponents.com/webdocs/0d72/0900766b80d72893.pdf
the PT is different and I haven't an LT1084-CT12 (I've tried to use an LM338 as current supply)
so I've some mod to the Power Supply
Also I've many doubts in my mind about all ground connections
Can you help me to complete the Input and Output transformers connections
and revise the layout for errors ?
I revised more times but I'm sure something of wrong is there !
MANY MANY THANKS IN ADVANCE
Kagliostro
p.s.: the .pdf file is more readable than the .jpg because of file limit dimensions
EDIT I had some problems with the attached files, hope now all is right
« Last Edit: January 05, 2011, 01:06:36 pm by kagliostro »
