August 29, 2026, 08:53:42 am
Hoffman Amps Forum image Author Topic: KT88's In a Plexi 50  (Read 5185 times)
Offline shortfuse
« on: January 07, 2011, 11:34:59 pm »
Finally received my replacement tubes from JJ Just installed them and turned bias adj all the way down and they idle at 57 - 59 ma.  Do I need to add a resistor or change one out using the 88's.  The first pair I received idled at 42ma and I ran them at 50ma.  Still didn't need to move the adj much at all.  While waiting on the replacements I used a set of KT77's out of my 5E7 and there was a lot of range adjustment.
I thought you could drop Kt88's as a direct replacement of EL34's without modifications?  Help Please.
Offline shortfuse
Re: KT88's In a Plexi 50
« Reply #1 on: January 08, 2011, 07:59:24 pm »
Did some more reading in the library and changed out the 47k for and 82k all is well and working fine.
