August 29, 2026, 08:52:57 am
Hoffman Amps Forum image Author Topic: Vacuum Tube base glue  (Read 10672 times)
Offline Tiny_Daddy
  • Get your Amp N Gear!
« on: January 11, 2011, 05:44:20 pm »
Finally a description:
http://www.antiquewireless.org/otb/vt0108.htm
It's a shellac and resin compound.
Does this mean that loose tube bases can be fixed with alcohol? I'll have to check.
Offline FYL
Re: Vacuum Tube base glue
« Reply #1 on: January 11, 2011, 06:59:11 pm »
Mostly marble flour (powdered marble):
" This recipe for RCA's basing cement, yielding about 200 pounds of material, was "standard for all bases." [9, 10]:
    Coarse marble flour      170 lb.
    Orange flake shellac      19-1/2 lb.
    Durite phenolic resin LR275-2      7-1/2 lb.
    Medium-color (grade G) rosin      3-1/4 lb.
    Denatured alcohol      9 liters
    Malachite Green aniline dye      10 g.
Offline stingray_65
« Reply #2 on: January 11, 2011, 09:45:46 pm »
don't forget the 150 C degree curing temp.
Offline LooseChange
    • Fix Your Darn Amps
« Reply #3 on: January 12, 2011, 04:40:22 am »
Did you try the alcohol?
Call me Dan
www.fydamps.com
Offline loogie
« Reply #4 on: January 12, 2011, 06:32:58 am »
Dude, alcohol isn't the answer to all problems.  Just some.  Maybe most.
Offline Bub
« Reply #5 on: January 12, 2011, 07:39:37 am »
Hi Gent's
Being new to this and not knowing the answer, would thin cyanoacrylate work?. You can get very small capillary tubes at hobby stores to inject the ca into the base.
Rob
Offline FYL
« Reply #6 on: January 12, 2011, 08:25:25 am »
Cyano works sometimes. You may use it on a cheap tube.
Emission Labs sells two versions of a dedicated tube base glue:
http://www.emissionlabs.com/datasheets/glue.htm
Available in Europe for €8.50 per bottle.
« Reply #7 on: January 12, 2011, 08:43:48 pm »
General-purpose Crazie-Gloo will fail at high temperatures.
Probably fine for battery-radio octals. Dubious on 6SN7. Will probably fail on 6V6/6L6 hot tubes.
Offline supro66
« Reply #8 on: January 13, 2011, 07:58:19 am »
J B Weld epoxy
500 Degrees F
I use this a lot
http://jbweld.net/products/jbweld.php
