September 16, 2026, 12:45:03 am
Hoffman Amps Forum image Author Topic: Line out solution  (Read 5734 times)
Offline firemedic
Line out solution
« on: February 10, 2011, 01:19:26 pm »
Hey all,
I've tried a few "line out" setups without much luck, but this one is the best I've seen so far. The others I've tried thinned out the sound a lot.
Though it's designed for a slave amp output, I put it in my TOS & recorded onto a regular old tape 4-track & it sounds real good. I used the 2.6k (I had a 2.7k on hand)/470R setup in the TOS & will try the lower values in my SE amp.
It looks like 5.5:1 is the magic ratio.
http://www.singlecoil.com/docs/out.pdf
« Last Edit: February 10, 2011, 03:37:58 pm by Geezer »
Offline Geezer
Re: Line out solution
« Reply #1 on: February 10, 2011, 03:35:35 pm »
Link not working.....
edit: fixed the link :wink:
« Last Edit: February 10, 2011, 03:37:42 pm by Geezer »
Offline firemedic
« Reply #2 on: February 10, 2011, 06:42:00 pm »
Thanks Geezer.
Offline stingray_65
« Reply #3 on: February 11, 2011, 07:56:26 am »
Good info!
Ray
Offline jeff
  • Need input
« Reply #4 on: February 11, 2011, 09:35:31 am »
 What does the 22ohm "soft grounding" resistor do?
Offline firemedic
« Reply #5 on: February 11, 2011, 09:57:03 am »
I guess that's useful if you're not common-grounding to the chassis. I didn't use it.
Offline OldHouseScott
    • Old House Recording Studio
« Reply #6 on: February 11, 2011, 10:32:06 am »
It helps to quell ground loop noise.
OldHouseScott
"We put a little quality in everything we build..."
