September 18, 2026, 03:04:17 pm
Hoffman Amps Forum image Author Topic: Massive current draw  (Read 5850 times)
Offline firemedic
« on: March 01, 2011, 06:15:29 pm »
I'm wrapping up my Pro reverb/vibroverb build. So far with no tubes the voltages appear OK, fine w/ preamp tubes only....When I plug in my power tubes the plate voltage drops to 226V and they appear to be drawing @150mA each. Then the fuse blows quickly. My bias circuit is the same as the Hoffman AB763 and the bias voltage is right; 52VAC, dropped to -65VDC max but I have it trimmed down to the minimum, -25VDC. At pin 5 both tubes are -11,-12V.
It does this whether the tremolo tube is in or out. I tried 2 sets of tubes that I know are good. The intensity pot is at its lowest setting.
What could be causing this massive current draw? I'm running out of fuses! Help!
Offline phsyconoodler
Re: Massive current draw
« Reply #1 on: March 01, 2011, 06:20:07 pm »
Set your bias pot so you have -50v at pin 5 of each power tube and try again. -25v will cook those tubes.
Offline firemedic
« Reply #2 on: March 01, 2011, 08:42:10 pm »
Okay, I tried maxing my bias voltage & found -66vdc at the insertion point (junction of the grid leak resistors) and -23vdc at the pins, with the amp on standby. The Fender schematic shows nominal          -51vdc at the junction, so I must be in the ball park as far as bias voltage goes.
But the same thing happens when I take it off standby- the grid voltage drops rapidly, the current skyrockets and the fuse dies. This is very frustrating.
Some mods I made, which I wouldn't think would cause problems:
- Grids 1 & 8 are tied together.
- 2.2k grid resistors, I ran out of 1.5ks
- Pentode-triode switch, drawing screen voltage from the plate
- 2.2k 5W screen resistors
- Power supply nodes: A- OT CT, choke, B- Screens & reverb trans, C- tremolo, D- driver, E- V4, V3, F- V2, G-V1.
- 100uF (2 in series) totem pole main filter (OT), 20uf for all other nodes
I'm stumped. And desperate. Please help.
Online sluckey
« Reply #3 on: March 01, 2011, 08:58:37 pm »
That's a bad sign! You should have exactly the same voltage on the pins as you have at the junction of the grid resistors. Pull the tubes and make the voltages the same before putting the tubes back in. There has to be a wiring error or the coupling caps from the PI are leaking badly.
« Reply #4 on: March 01, 2011, 09:19:08 pm »
Do you have grid leak resistors on the power tubes?  Are their connections solid on both ends: G1 pin & ground?
Offline firemedic
« Reply #5 on: March 01, 2011, 09:21:21 pm »
I've stopped for the nite but I wouldn't be surprised if my .1 coupling cap is leaking, I'll fix that tomorrow. I've had a few .1s go bad before (chinese metal polyester).
Dumb question: the 220k doesn't drop the voltage at all?
Online sluckey
« Reply #6 on: March 01, 2011, 09:47:30 pm »
There is no current flow thru the 220K unless something is wrong, ie, wiring error or grid drawing current (not normal).
Look at page 5 of this pdf for a visual...
http://home.comcast.net/~seluckey/amps/misc/Amp_Scrapbook.pdf
Don't put the big tubes back in until you fix this.
« Last Edit: March 01, 2011, 09:50:15 pm by sluckey »
Online sluckey
« Reply #7 on: March 01, 2011, 09:52:43 pm »
It's fixed bias. The grid leaks better be connected to the bias supply.
Offline firemedic
« Reply #8 on: March 02, 2011, 11:03:05 am »
It was leaky coupling caps. I took out all the cheap 0.1uFs & replaced them with big ODs- problem solved. This is my 1st fixed bias amp so I'm at the bottom of the learning curve.
Stay tuned for more tweaking issues- I replaced the normal channel with a 5879 and a low-loss tonestack. So more on that soon...
Thanks sluckey for knocking the rust loose!
