September 08, 2026, 03:50:12 pm
Hoffman Amps Forum image Author Topic: new amp    (Read 5676 times)
Offline Geezer
new amp
« on: June 17, 2005, 09:14:18 pm »
        > new amp
<< Prev Topic | Next Topic >>
Author  Comment
Leevi
Junior tube assistant
(2/9/04 1:39 pm)
 new amp
 I have finally finished the Rikstone C15 combo. Thanks for the help. www.kolumbus.fi/risto.kiv...stoneAmps/ (click Rikstone C15)
/Leevi
Leevi
(2/9/04 1:52 pm)
 images
 Oops, the images didn't succeed, new links below:
Leevi
www.kolumbus.fi/risto.kiv.../C15_1.JPG
www.kolumbus.fi/risto.kiv.../C15_2.JPG
www.kolumbus.fi/risto.kiv.../C15_3.JPG
www.kolumbus.fi/risto.kiv.../C15_4.JPG
www.kolumbus.fi/risto.kiv.../C15_5.JPG
www.kolumbus.fi/risto.kiv.../C15_6.JPG
jc
I only work on Fender's
(2/9/04 5:30 pm)
 Re: images
 Leevi,
It looks great. I like the purple. Can you post an MP3?
Edited by: jc at: 2/9/04 5:55 pm
ganzonimx
Hey get your own solder
(2/9/04 6:21 pm)
 Re: images
 Very nice finish, I like the SS faceplate. Did you think about the lettering?
I wounder if there is a way to do some serigraph printing on it and what kind of paint should be used, as I use also SS faceplates on my projects.
Cris
Leevi
(2/10/04 1:52 am)
 Re: images
 Hi,
Thanks for the comments. I also noticed that the grill looks like a purple in the picture but in the day light it looks like more blue. To produce good MP3s is little bit difficult for me. Firstly I don't own any good recording systems and secondly I can't play so well. Maybe some day if I find a good guitarrist and recording studio I'll post them.
If somebody knows a good and reasonable way to do fine prints on the faceplate I'm interested in that. I don't own any engrave machine which might be a solution for that.
Because of that I don't print any texts on the faceplate. On the back plate I use often text tapes for pratical/informational reasons.
/Leevi
Tyrannocaster
(2/10/04 8:33 am)
 C15
 Hey, Risto;
As usual, your amp build looks great! (If you don't recognize my name it's because you know me under a different one from our emails...about American movies :-)
What about using a decal for a quick-and-dirty label? It's not the perfect solution, but it does work and for someone with a computer and a printer it can produce pretty good results. It's even somewhat durable if you lacquer it.
As for mp3's - send me the amp (I'll get my own mains transformer) and I'll do some for you. :-)
Leevi
(2/10/04 1:33 pm)
 C15
 Hello Rick,
I'm using my nick name here, actually Leevi is the name of our dog (dachshund). I'm sorry but I don't understand exactly what "decal" means. Is that some kind of pressing method? I have pressed separate letters on the faceplate before but the result was not good enough. The letters disappear lightly if you often touch them.
/Leevi
Platefire
Guest comedian
(2/10/04 6:11 pm)
 NICE!!!
 Nice peice of work!!!! Did you do the cab yourself?? I like it!!
Plate
bluetonene
(2/10/04 6:34 pm)
 Re: NICE!!!
 I'm experimenting with iron on transfers on the back of plexi glass. Then spraying the entire back gold. This way the writing is behind the glass to protect it. I should have results this week end. If anyone is interested, I'll post my findings.
stan buczko
(2/10/04 9:23 pm)
 Re: NICE!!!
 Yes, please post your findings. And were did you get the iron on transfers?
Stan
bnwitt
Senior tube assistant
(2/10/04 10:31 pm)
 Re: NICE!!!
 "I'm experimenting with iron on transfers on the back of plexi glass. Then spraying the entire back gold. This way the writing is behind the glass to protect it. I should have results this week end."
sounds like a lot of work to me. I could make you a reversed etched plate in gold plexi with black letters for about $40 on my computer engraving machine. I could include a logo as well if you'k like. Back panels are also not a problem. See this thread for Waynes plate:
pub189.ezboard.com/fhoffm...3386.topic
Barry
Edited by: bnwitt at: 2/10/04 10:36 pm
Leevi
(2/11/04 1:33 am)
 Re: NICE!!!
 Yes, I'm interested in your plexi glass method.
The Waynes plates are great.
A: I have made the cab, the material is 18mm (3/4") pine finsihed with imitation leather, no screws have been used in construction.
/Leevi
bnwitt
(2/11/04 10:29 am)
 Re: NICE!!!
 Leevi,
I would need a layout drawing with exact dimensions and hole sizes. Where are you located? What I normally do is take your drawing and produce a paper layout for your final verification of correct alignment to your chassis before I cut the final plate. My email is bnwitt@hotmail.com
Barry
Leevi
(2/11/04 11:35 am)
 Re: NICE!!!
 Barry,
I'm sorry, I did't mean that I'll order your faceplate. My interest was directed to this method in general. I'm also waiting for the results from Bluetonene. Besides I'm probably located far away from your place.
/Leevi
Ritchie200
(2/11/04 1:54 pm)
 Re: new amp
 Hey guys,
If I need to do any kind of marking on metal faceplate's I use a little gadget called an Etch-o-matic. The company is called Martronics. Just do a web search. Anything you can produce and print on your computer, you can make a stencil for. The stencil process is similar to PC board etching. Depending on the chemicals you use, you can do clear or black etching a few thousands of an inch deep. You can even do logo's. THe whole starter system is not cheap, but the stuff lasts forever and if you are constantly running to the engraver - it will eventually pay off. THe only recommendation I have is that you do a few test etches before you tackle your polished SS pride and joy! Good luck!
BTW, something I have also done with this is do a clear etching and fill it with enamel. That way you can do colors - if you protect it.
Great job on the amp Leevi!!!
bnwitt
(2/11/04 10:06 pm)
 Re: NICE!!!
 Leevi,
well as far as my method, it requires about $35,000 worth of equipment and software but it does produce fine results. I hope you find a good solution wherever you are, as your amps deserve a quality plate.
Barry
Leevi
(2/12/04 10:29 am)
 Re: NICE!!!
 Ritchie,
What type of the etch-o-matic devices do you use? The starter kit published on the pages below costs 69,95 USD. Do you think that device is good enough or should it be a more professional model.
/Leevi
www.etch-o-matic.com/EOM.html
ganzonimx
(2/12/04 12:30 pm)
 Re: NICE!!!
 Hey Jim
thats a great gadget indeed! But is it relay that easy? how long did it take you to get good etching? I'm kind of suspicious about all those "perfect easy to use in 3 minute learned" things sold on the internet. Could you post a pic of something you etched, I'l think that would help us to spend these 70 bugs...
Cris
Ritchie200
(2/12/04 1:17 pm)
 Re: NICE!!!
 Ha! I know what you mean about the too good to be true advertising! It is actually very easy to use. Just practice a few and you will be an expert. However, you need to get the Dura-Film stencil making "Kit" which is $150.00 alone (on sale!!! for the last couple of years....). They have a bare bones starter kit for $199.00, which includes the Dura-film kit and the part marker. THe stencil kit that comes with the $60.00 (or whatever) unit is only good for simple marking. Those stencils are made using a manual typewriter or dot matrix printer. The dura-film unit allows you to do anything that you can make on your computer screen and print out. The only advice I would give with logo's is that this thing does not do shading, so make sure your contrast is very high - basically black or white.
I ran across this unit trying to figure out a way to permanently mark replacement tooling at the company I work for. We put part numbers and our company name and logo on everything. It looks exactly like what you see in their ad - very clear marking. Sorr
