September 14, 2026, 02:29:27 pm
Hoffman Amps Forum image Author Topic: VISHAY METAL FILM RESISTORS  (Read 6570 times)
Offline dpm309
    • Matthews Amps
« on: April 03, 2011, 05:15:54 pm »
I just received an order from Mouser that included 1 and 100 Ohm, 1 watt metal film resistors made by Vishay/BC Components.  At first I thought they shipped the wrong resistors but I doubled checked the invoice and the data sheet and they are supposed to be 1 watt resistors.  These are the same size as a 1/4 watt resistor (see attached photo).   According to the data sheet, the length is only 6.5 mm and the diameter is 2.5 mm.  I am hesitant to use these because of their size. Has anyone used these before?
Dan
Offline G._Hoffman
Re: VISHAY METAL FILM RESISTORS
« Reply #1 on: April 04, 2011, 03:17:34 am »
I've used those - they are fine.  Well, not in those values, but still...
Gabriel
Offline dpm309
    • Matthews Amps
« Reply #2 on: April 04, 2011, 10:23:00 am »
Thanks for the reply.  After I posted this, I saw where Doug is selling the same resistor with a 1% tolerance.  I'll go ahead and use them.
Dan
« Reply #3 on: April 04, 2011, 05:37:33 pm »
The power rating of a resistor is only about how HOT it can get (without smoking or drifting).
The old flowerpot-clay resistors did not like to get TOO hot.
These wee beasties are made like kiln insulators: high-grade ceramic. You can probably take them up to red-heat and safely dissipate 4X the watts of a same-size composition; or get the same watts in a 4X smaller blob.
Don't be fooled. Heat is heat. You know a old-style "1W" resistor needs a lot of space for air to flow. These parts are smaller, but need the same total cooling space.
Offline ThermionicEngine
  • ooops- Should have cut the blue wire first
« Reply #4 on: April 04, 2011, 08:28:48 pm »
Metal Film resistors have a military rating and a commercial.  Military 1/2 Watt = Commercial 1 Watt.  I think they are fine resistors but I tend to use them where size is an issue, like in new Fender amps where they use 1/4 Watt resistors and I want a more robust resistor.
The board only allows so much room.  (With due notice about heat dissapation as mentioned by PRR above. I just raise them off the board if it is a warm spot.
V= IR; Everything else is derivative...
