September 16, 2026, 08:16:17 am
Hoffman Amps Forum image Author Topic: what zener to use to drop 30v  (Read 34484 times)
Offline J Rindt
Re: what zener to use to drop 30v
« Reply #50 on: May 07, 2011, 11:47:13 pm »
Do I have to calculate some type of current that the Zeners will see.?
I need to drop about 30 Volts in this circuit. The field coil is gone, replaced with a regular speaker.
http://f1.grp.yahoofs.com/v1/QBXGTXTuJF6Q-MFjhkvW88j4_7y-dBouWuAaw6kcOJvUA42_02XsguHCOrPV0Uw-LsI_vjxZtKUq87_gYTO3MmypvMY-DQbRFIA6Tc2ByV4/Schematics/Magnatone%20M-192-5.gif
It would be awesome if one of you guys that have graphics/computer skills, could get this info visible. I appreciate how much effort that might take, and I wish I had the knowledge/software to do it myself. But if some of these PS Voltage Dropping techniques could be preserved in schematic/lay-out form, it would be a huge assistance for future builds, builders, discussions.
Thank You
This is what I have done.
The zeners can be a combination of 10v, 14v 18v (or whatever value you wish) to acheive the desired voltage drop. The zeners shown give an approximate 50v reduction.
« Reply #51 on: May 08, 2011, 01:43:07 am »
Thank You
On a High Tension winding you can bank on about 80-100mA for an amp with a pair of  6V6s or about 140-180mA for an amp with a pair of 6L6s. Use 5W axial zener(s) mounted on a tag strip reversed-baised (cathode/banded end pointing to ground). For a FW rectifier, put the zener(s) to ground in series with the High Tension centre tap. For a bridge rectifier, put the zener(s) to ground in series with the ground side of the rectifier. For a 30V drop, use either 2 x 15V, or 3 x 9V, or 2 x 9V and a 12V or some such (all in series).
Offline J Rindt
« Reply #52 on: May 08, 2011, 10:17:10 am »
Thank You So Much........ :thumbsup:
« Reply #53 on: May 08, 2011, 01:23:15 pm »
Is this another way to solve the problem ??
(about schematic I've read there are mistake on pin connections in the schematic)
http://spinoo.free.fr/projetG5/charpy/Zener2.pdf
Kagliostro
Offline Tone Junkie
« Reply #54 on: July 04, 2011, 05:32:08 pm »
Ok I finally found the one I was looking for.
Thanks Bill
Offline RobBozic
« Reply #55 on: July 04, 2011, 09:51:58 pm »
I've used the circuit on the left to drop about 50V.
Apologies if someone's already posted this, I couldn't be bothered reading through the whole thread.
Rob
Offline xm52
« Reply #56 on: July 05, 2011, 07:55:21 am »
In some applications you can use a tube, such as a 12AX4GT to drop the 30 volts. This is a really neat half wave rectifier tube. Connect the cathode to the HV center tap, the plate to ground through a fuse, and the heater voltage.
The advantage is slow turn on and a built in voltage drop.
« Last Edit: July 05, 2011, 08:11:55 am by xm52 »
Offline Fresh_Start
  • noob de Lux
« Reply #57 on: July 05, 2011, 09:51:12 am »
Rob
Rob - Thanks for that Aiken sheet.
Chip
Quote from: jjasilli
Quote from: PRR
Offline Tone Junkie
« Reply #58 on: July 14, 2011, 01:11:01 am »
Someone up top was looking for this.          Bump    :think1:
Bill
Offline Tone Junkie
« Reply #59 on: December 05, 2012, 02:44:29 am »
Found this one Geezer sent me when I was looking for it.
Didnt we also have another discussion on this were someone put the zeners in line with the B+ to drop it.
could some one find that one, I have been looking but cant seem to locate it. Im trying to put all the differant ways in my notes for future referance.
Thanks Bill
« Reply #60 on: December 05, 2012, 08:33:03 am »
If you don't have stored it previously
here is one other method
Offline Tone Junkie
« Reply #61 on: December 05, 2012, 02:49:08 pm »
Thanks kagliostro
Offline billcreller
  • 1934
« Reply #62 on: December 24, 2012, 08:17:56 pm »
I just tried the "backward" filter cap and resistor trick.  It worked good. I had a pair of 680 ohm 10 w resistors, and just hooked it with those in parallel to check it out.  It went from a bit over 500 down to 318. A bit too low for what I want, but I can adjust it up. And those resistors didn't get warm......
Offline Tone Junkie
« Reply #63 on: December 26, 2012, 03:19:51 am »
Bill could you post that one.
Thanks Bill
Offline jazbo8
« Reply #64 on: December 26, 2012, 04:36:15 am »
Offline billcreller
  • 1934
« Reply #65 on: February 03, 2013, 02:19:14 pm »
I dug up this old thread to review it.  When I tried to get the B+ voltage up where I wanted it, around 380 etc, from the too-low 318 volts, using lower value resistors, I noticed that the voltage before the resistor/cap combo was the same as the output side of that combo, while the voltage from the rectifier tube remained high.  SO is the rect. tube going to get "over-loaded" with this arrangement ?
  This is some weird shit to me !! :icon_biggrin:
Offline phsyconoodler
« Reply #66 on: February 04, 2013, 10:51:55 pm »
I've used this before and never had an issue with loading the rectifier.It's all about the relationship with the center tap to ground.Adding the resistor doesn't necessarily add load.It does add some reverse voltage though,so that's why the filter cap gets reversed like on a bias tap.
  I don't really understand it but I do know it works just fine.
« Reply #67 on: February 05, 2013, 12:12:00 am »
Here you can find a very good explanation and documentation about what happen adding a resistor between the CT and ground
That solution has more than a purpose
http://www.aikenamps.com/BackBiasing.html
@ Billcreller
If you measure the voltage before and after a drop resistor as to have a difference on the measured voltage, there must be a load, if no current is going across the drop resistor no drop is produced
For this reason you must also consider that in a class A amp the current consumption is near always the same, in an AB1 circuit the current changes much more from idle to full roar, so the drop resistor acts also as a SAG resistor (in junction to the SAG effect given by the Tube Rectifier) and after the drop resistor you can measure a higher voltage at idle than at full roar
Have you get your measures without tubes ?
« Last Edit: February 05, 2013, 12:31:29 am by kagliostro »
Offline billcreller
  • 1934
« Reply #68 on: February 09, 2013, 09:52:34 pm »
 The voltage readings were with tubes.  Also., my "field resistor" which takes place of a field coil type speaker. is getting hot, and that's not happened with all the clones I've built of this amp.
I think it's time to back off & replace the PT with the right type :icon_biggrin:
