September 14, 2026, 04:23:48 am
Hoffman Amps Forum image Author Topic: Just one question on my Champ AA764 home brew on the OT taps  (Read 4322 times)
Offline catnine
  • I am wordy and frustrating EAYOR
 The weber OT is like a Champ OT only is has two taps  a 4 ohm and 8 ohm . I have the NFB 2.7k ohm resister connected to the 4 ohm tap and the 8 ohm speaker to the 8 ohm tap I was told on this forum that that was ok because the feedback sees the tap and the end result would be the same. I did a seach here but the post goes back to far . Does this sound right ?
Offline phsyconoodler
Re: Just one question on my Champ AA764 home brew on the OT taps
« Reply #1 on: June 29, 2011, 04:59:14 pm »
sounds right to me.The tap gets it's message back to the OT no matter what tap it's connected to.However,there may be a different effect if you hook it up to the 8 ohm tap.Good or bad,it will sound a bit different.
