September 14, 2026, 09:11:40 am
Hoffman Amps Forum image Author Topic: 66 Vibrolux Issues  (Read 8396 times)
Offline fiftynine
66 Vibrolux Issues
« on: July 16, 2011, 10:55:31 am »
I have a 66 AA864 Vibrolux Reverb (GZ34) but can't find a schematic. I've been working to the AA964 schematic (also GZ34), and it's just been pointed out to me that that's the only schematic saying 315vAC, the rest say higher. That makes sense as the Mojotone replacement tranny chucks out 355. Incidentally, my tranny didn't come with a heater centre tap. Strange as most I've seen have, as does the schematic.
But, I did the filter caps to the AA964 schematic (16uf across the board like a Deluxe Reverb) and not with the larger cap and resistor combinations for the first stage like later Vibroluxes and bigger Blackfaces.
Is the five 16uf setup sufficient for my amp? Why did it change?
« Last Edit: July 16, 2011, 12:26:14 pm by fiftynine »
Offline VMS
Re: 66 Vibrolux Issues
« Reply #1 on: July 16, 2011, 04:06:18 pm »
Go with AA964. According to this thread, bias circuit may have different value resistors but otherwise they are the same:
http://music-electronics-forum.com/t2563/#post20127
Offline VMS
« Reply #2 on: July 16, 2011, 04:14:54 pm »
Are you sure about the heater center tap?
Specs show a GREEN/yellow CT:
http://www.mojotone.com/core/media/media.nl?id=12526&c=923962&h=1cee15546bae8ac95116&_xt=.pdf
...but if it is missing then make it with 100R resistors.
Offline fiftynine
« Reply #3 on: July 16, 2011, 06:28:39 pm »
AA964 it is then.
Definately no heater CT :dontknow: so the 100's are in. Quiet as a mouse.
« Reply #4 on: July 16, 2011, 11:04:26 pm »
Those are among my all-time favorite amps. I'm not incredibly fond of 10" speakers in general, but a Vibrolux is almost the perfect package. I had a brown Vibroverb which I sold to Mr. Groove, Austin Pittman. Fender did not make a 35-watt amp driving a single 12" speaker for some reason. They shoulda!
Offline fiftynine
« Reply #5 on: July 17, 2011, 06:26:51 pm »
Oh yeah, no 2 x 6l6 1 x 12" in the BF line up. Well I never.
A quick question, if I've got 650mV at the pots side of the 0.1uf 200v cap (the last blue molded before the PI), does it need replacing? All other blue moldeds read very few millivolts.
Cheers.
« Reply #6 on: July 17, 2011, 08:02:29 pm »
No. If you look at the schematic you'll see dc voltage on both sides of that cap.
Offline fiftynine
« Reply #7 on: July 27, 2011, 01:30:38 pm »
Ok.
Can anyone hazard a guess as to why my vibrato intensity is a bit shallow? Are there any specific components that drift and would do that? I didn't want to go unsoldering caps for originality sake.
All electrolytics done by the way.
« Reply #8 on: July 27, 2011, 01:47:34 pm »
Ok.
The trem is bias-vary in the aa964. As the bias gets hotter the trem intensity decreases. If you make the bias adjustable (always a good idea), you will be able to cool it down, and get more slam in the trem.
Offline fiftynine
« Reply #9 on: July 27, 2011, 02:09:22 pm »
Tubeswell, it's the opto-isolator trem as in AA964. I thought it was only the Princeton that got the bias-vary in the Blackface line up?
« Reply #10 on: July 27, 2011, 02:22:38 pm »
de roach
Offline fiftynine
« Reply #11 on: August 02, 2011, 08:56:13 am »
Yup. Ta.
Can anyone tell me why my 2 x Jensen C10Q's read 6.3 and 6.2 ohms on their own and only 3.12 ohms hooked up in parallel? I have the original Jensen C12N's just been re-coned and ready to go in. They measure 5.1 and 5.4 ohms, 2.6 hooked up.
Is this right? Is it bad for my output tranny? For performance, tone and volume etc?
Offline firemedic
« Reply #12 on: August 02, 2011, 09:03:08 am »
That sounds about right. An 8ohm speaker will read somewhat less than 8 on a VOM. 2 8ohm speakers in parallel will read less than 4 ohms.
« Reply #13 on: August 02, 2011, 10:06:02 am »
Offline fiftynine
« Reply #14 on: August 02, 2011, 03:18:06 pm »
Sluckey, thanks I did the maths before I posted. I hope I don't come across as a non-tryer. It's the low DC resistance, especially of the vintage speakers that concerns me. I've measured speakers before and never got quite that low for an 8 ohmer.
I know the resistance in operation is different but 2.6 ohms hooked up is pushing it for me.
« Last Edit: August 03, 2011, 04:07:26 am by fiftynine »
